EK foglights.
EK foglights.
So I have an EK, I just got it yesterday, I have no idea why the foglights aren't working anymore. The day I went to go look at the car, the lights turned on with no problem, today, I tried to turn them on at night, they didn't come on. I believe they are wired up. When I turn on the swith for the fogs, the little light comes on, but the fogs dont come on.
EK owners with fogs on their car, please help out a noob.
Re: EK foglights. (Adankid)
Well it could be a number of problems because the switch light does turn on. I do not think it is the relay because of that fact. There is two grounding points on the wires for the EK fogs and a plug that goes into the fuse box I would check the grounding points first if i were u. There is 1 by the driver side foglight and there is 1 underneath the panel where your switch is located. If not check the bulbs.
Re: EK foglights. (dudeomega2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dudeomega2000 »</TD></TR><TR><TD CLASS="quote">Well it could be a number of problems because the switch light does turn on. I do not think it is the relay because of that fact. There is two grounding points on the wires for the EK fogs and a plug that goes into the fuse box I would check the grounding points first if i were u. There is 1 by the driver side foglight and there is 1 underneath the panel where your switch is located. If not check the bulbs. </TD></TR></TABLE>
X2, start with the fuse, that would be a prime cause for both lights not to work.
Re: EK foglights. (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">
X2, start with the fuse, that would be a prime cause for both lights not to work.</TD></TR></TABLE>
Lol... yeah i forgot about the fuse as well.
dubniK
10-31-2003 01:49 PM
