Question for the engine builders???
Old Jan 8, 2006 | 10:37 AM
CBURKE's Avatar
Default Question for the engine builders???
I am building a B18A, I will be using the stock rods with Wisco pistons. I am sending the block, crank, and rods to the machine shop. The crank looks pretty good, but I will be having micro polished. My question is, when it's time to get the new bearings do I just say "I need rod and crank bearings for a 91 Acura"? I have only built Mtsu motors and I have read some stuff about Honda having different color bearings. I don't see anything that tells me what bearings are on there now. I see this 2-0 on each cylinder at the bottom, but I don't think that has any thing to do with it. Any help would be great thanks.
Old Jan 8, 2006 | 11:07 AM
CBURKE's Avatar
Ok, I did some serching and I think I got it. There are some letters on the block and letters and #'s on the crank. You just match them up with the book and that will tell you.
Old Jan 8, 2006 | 11:08 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Question for the engine builders??? (CBURKE)
If you get aftermarket bearings,they will all be one size.
If you are rebuilding to "factory specs,"
There are letters on the crankshaft and on the back of the block
that will specify with bearing to use..
Old Jan 8, 2006 | 11:13 AM
CBURKE's Avatar
Default Re: Question for the engine builders??? (88DXCRX)
In your opinion what would be the best?
Old Jan 8, 2006 | 11:18 AM
Rukusmasta2's Avatar
OEM color
Old Jan 8, 2006 | 11:26 AM
jlicrx's Avatar
i believe you will find that you can't use Wiseco pistons with the stock rods - stock rod has pressed in pins - Wiseco pistons use full floating pins
Old Jan 8, 2006 | 11:31 AM
88DXCRX's Avatar
Default Re: Question for the engine builders??? (Rukusmasta2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rukusmasta2 &raquo;</TD></TR><TR><TD CLASS="quote">OEM color </TD></TR></TABLE>
For sure...If money is no object use OEM..
Honda engineers took the time to measure the clearances
and record them for a reason. &gt;Longevity.
Old Jan 9, 2006 | 06:51 AM
CBURKE's Avatar
Default Re: Question for the engine builders??? (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">i believe you will find that you can't use Wiseco pistons with the stock rods - stock rod has pressed in pins - Wiseco pistons use full floating pins</TD></TR></TABLE>
Yeah, but they can go ether way from what I am reading. Here I am getting them from Summit: Wrist Pin Style: Press fit or floating
http://store.summitracing.com/...42368
blackcrx16
Oct 14, 2007 08:02 PM
dohcdelsol
May 3, 2006 09:20 AM
JSPECHB
Dec 21, 2004 01:17 PM
eddie1681
Apr 17, 2002 02:42 AM
