CEL? T1R Test Pipe?
Old Jan 7, 2006 | 11:55 PM
rcar97's Avatar
Default CEL? T1R Test Pipe?
Hey guys, anyone running the secondary O2 sensor with a test pipe able to get no CELs? If so, how? I want to try the spark plug non fouler solution but I'm not sure its going to clear the floor of the car. Others ideas? looking at that light all the time is going to drive me crazy.
Old Jan 8, 2006 | 09:21 AM
RedKroovy's Avatar
Default Re: CEL? T1R Test Pipe? (rcar97)
Well I have a o2 sensor sim that wires into the ecu. I recieved mine from Hogens Import Parts, his username is Tweakmeister. Hit him up for one.
Old Jan 8, 2006 | 09:47 AM
onyx00's Avatar
Default Re: CEL? T1R Test Pipe? (RedKroovy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedKroovy &raquo;</TD></TR><TR><TD CLASS="quote">Well I have a o2 sensor sim that wires into the ecu. I recieved mine from Hogens Import Parts, his username is Tweakmeister. Hit him up for one.</TD></TR></TABLE>
No need to pay for an O2 Sim (which sounds like the biggest bunch of bullshit I have ever heard...)
Some simple caps. and resistors will prevent the CEL. Search the archive posts, there is some stuff about doing this. If you do buy an O2 Sim, I wouldn't pay more than $50 for it; and that is still probably too much!
Old Jan 8, 2006 | 12:15 PM
get RIGHT's Avatar
I have the exact same problem.
With the the exact same parts in use.
Yeilding the exact same results...rcar97
After a year w/ the CEL on, it has now blended into being "just part of the dash lights now."
Old Jan 8, 2006 | 06:50 PM
rcar97's Avatar
Default Re: CEL? T1R Test Pipe? (ITR 00-0477)
I hear ya, so I guess the power gains offset the annoyance of the light being on?
Does it even make more power?
Does the car run differently at all?
Thanks for the reply
Old Jan 9, 2006 | 05:48 AM
JDM Factor's Avatar
Make sure you don't have problems with the primary. If your crazy about the light being on for your secondary, contact Ken (blackR). He has plug and play foolers so you don't have to cut into the factory wiring harness unlike those o2 sims out on the market.
Old Jan 10, 2006 | 12:28 PM
rcar97's Avatar
Default Re: CEL? T1R Test Pipe? (JDM Factor)
Thanks
Tiger_Si
Aug 16, 2008 09:34 AM
beastman@
Jul 10, 2008 08:53 AM
jdmboy
Honda S2000
Oct 13, 2005 01:25 PM
sivicman
Jun 2, 2002 11:09 AM
Ri5e
Sep 16, 2001 07:36 PM
