Test pipe CEL question
Old Jul 1, 2008 | 06:38 PM
beastman@'s Avatar
Default Test pipe CEL question
If I have a test pipe with o2 bung, and I put the o2 sensor in it, will I get a CEL?
(The other o2 sensor will be in the header.)
Old Jul 1, 2008 | 06:58 PM
Dredakid05's Avatar
Default Re: Test pipe CEL question (beastman@)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beastman@ &raquo;</TD></TR><TR><TD CLASS="quote">If I have a test pipe with o2 bung, and I put the o2 sensor in it, will I get a CEL?
(The other o2 sensor will be in the header.)</TD></TR></TABLE>
no
Old Jul 1, 2008 | 11:01 PM
hotrod99's Avatar
Default Re: Test pipe CEL question (Dredakid05)
you will if your car is obd2
Old Jul 2, 2008 | 12:13 AM
01GSRDC2's Avatar
Default Re: Test pipe CEL question (hotrod99)
yeah if your car is obd2 you will. i have a test pipe with 02 bung and the secondary 02 sensor in it...ive had a cel for 2 years lol never got around to installing my home made 02 sim
Old Jul 2, 2008 | 04:18 AM
beastman@'s Avatar
Default Re: Test pipe CEL question (01GSRDC2)
Yeah I've got a 98, that sucks.
What about with a high flow cat? CEL yes/no?
Old Jul 2, 2008 | 04:48 AM
hotrod99's Avatar
depends on which one you get...try the 400cell carsound cat,that shouldnt set off the cel...and if worst comes to worst you could always get an o2 simulator
Old Jul 2, 2008 | 05:57 AM
dc4_wHORE's Avatar
Soldering Iron Wizardry
blox makes a CEL eliminator. might wanna check it out
Old Jul 2, 2008 | 09:32 AM
beastman@'s Avatar
Default Re: Test pipe CEL question (dc4_wHORE)
This may sound stupid, but if the o2 sensor throws a code when it doesn't get enough oxygen, couldn't you just let it sit outside the test pipe/cat where there's plenty of o2? Or will too much oxygen throw a code as well?
Anyone using the blox eliminator on an OBD2? How well does it work?
Old Jul 2, 2008 | 10:23 AM
hotrod99's Avatar
it would still throw a code if its not hooked up
Old Jul 2, 2008 | 12:56 PM
beastman@'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Anyone using the blox eliminator on an OBD2? How well does it work?</TD></TR></TABLE>
x2
Old Jul 9, 2008 | 05:34 PM
beastman@'s Avatar
Anyone using this CEL eliminator?
Old Jul 9, 2008 | 08:04 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beastman@ &raquo;</TD></TR><TR><TD CLASS="quote">Anyone using this CEL eliminator?</TD></TR></TABLE>
since you're asking this, i'm assuming your car is obd2. do a search for "spark plug defouler". it cost me ~$5 when my 99 gsr was turbo'd and my cel went away (had to pass emissions testing).
Old Jul 10, 2008 | 06:39 AM
beastman@'s Avatar
Default Re: Test pipe CEL question (vladd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vladd &raquo;</TD></TR><TR><TD CLASS="quote">
since you're asking this, i'm assuming your car is obd2. do a search for "spark plug defouler". it cost me ~$5 when my 99 gsr was turbo'd and my cel went away (had to pass emissions testing).</TD></TR></TABLE>
What does that have to do with an o2 sensor?
Old Jul 10, 2008 | 08:53 AM
vladd's Avatar
What does that have to do with an o2 sensor?</TD></TR></TABLE>
Its obvious you haven't searched. You enlarge the hole in the defouler so the o2 fits, stick it in the secondary o2 bung, and then stick the secondary o2 in the defouler. This way less gas reaches the sensor and it thinks its been cleaned up as if it had gone through a functioning cat.
Ghetto Civic HX
Dec 19, 2007 10:17 AM
IntegraCF21
Sep 24, 2005 04:42 AM
comptechgsr2000
Apr 25, 2002 09:26 PM
YaMaJeSty
Feb 27, 2002 05:06 AM
