Honda S2000 Honda S2000
s2k test pipe
Old Oct 8, 2005 | 09:44 AM
jdmboy's Avatar
Default s2k test pipe
i just wanted to know wat kinda test pipe could you use on and s2000 stock exaust and header?
Old Oct 8, 2005 | 10:38 AM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: s2k test pipe (jdmboy)
Any. Search.
Old Oct 8, 2005 | 11:29 AM
SuzukaBlueAP2's Avatar
Default Re: s2k test pipe (Sideways2000)
word. If you're crafy, you can make your own. If not, they are not hard to come by.
Old Oct 8, 2005 | 12:39 PM
papa5murf's Avatar
Default Re: s2k test pipe (ScreaminTeg)
it's just a pipe... you can pick and chose which one you want.. there's plenty out there...
Old Oct 8, 2005 | 07:20 PM
bridow's Avatar
Default Re: s2k test pipe (03s2kblue)
t1r is around 99 bucks
Old Oct 12, 2005 | 01:13 PM
darmaintenance's Avatar
Default Re: s2k test pipe (bridow)
I think some of the pipes may cuase a reading from the O2 sensor. You may want the pipes that keep the O2 sensor away from the exhaust stream.
Old Oct 12, 2005 | 01:17 PM
papa5murf's Avatar
Default Re: s2k test pipe (darmaintenance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darmaintenance &raquo;</TD></TR><TR><TD CLASS="quote">I think some of the pipes may cuase a reading from the O2 sensor. You may want the pipes that keep the O2 sensor away from the exhaust stream.</TD></TR></TABLE>
only one test pipe has a built in 02/CEL fix.. and thats the berk technologys one.. all the rest you have to modify it in order to get rid of the CEL light.. but it's an easy fix that should cost you no more then 10 bucks..
Old Oct 13, 2005 | 08:15 AM
How can I fix the 02/CEL?
Old Oct 13, 2005 | 12:50 PM
papa5murf's Avatar
Default Re: (darmaintenance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darmaintenance &raquo;</TD></TR><TR><TD CLASS="quote">How can I fix the 02/CEL? </TD></TR></TABLE>
http://www.s2ki.com/forums/ind...&st=0
Old Oct 13, 2005 | 01:25 PM
Default Re: (03s2kblue)
Thanks
mxracer420
Mar 25, 2010 04:33 PM
kevinm1981
Oct 7, 2009 02:58 PM
sivicman
Jun 2, 2002 11:09 AM
