Is This Okies Or Bad Turbo
This is my friend turbo kit (greddy)...He had it for his 94 gsr for 1 month and he want to sell it too me...I'm just wondering if it good or not, and im just wondering what is that black line on the turbo??
So please help me out alrite before i buy the turbo kit...
Modified by ILoveHonda510 at 12:35 AM 1/8/2006
Modified by ILoveHonda510 at 12:36 AM 1/8/2006
Who is Mr Robot?
we cant tell **** from the pics.. we need photos of the compressor and turbine wheel. quit bumping it dammit
The black tubing on the turbo compressor should be hooked up to the internal wastegate diaphragm, unless you have a boost controller then depending on what kind, it will be hooked up to it.....
Marlon, the way it is connected right now on the picture, it seems like it is already connected to a boost source, which is the compressor housing itself. Otherwise, you'd be right if the other end of the tubing is already connected to the internal WG diaphragm. Maybe we can get a close up picture?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thermal »</TD></TR><TR><TD CLASS="quote">The black tubing on the turbo compressor should be hooked up to the internal wastegate diaphragm, unless you have a boost controller then depending on what kind, it will be hooked up to it.....
Marlon, the way it is connected right now on the picture, it seems like it is already connected to a boost source, which is the compressor housing itself. Otherwise, you'd be right if the other end of the tubing is already connected to the internal WG diaphragm. Maybe we can get a close up picture?</TD></TR></TABLE>
That`s why I said that it has to go on the wastegate vacum/boost source because it`s already hooked up the the compressor side housing so the other side of the pipe has to go on the wastgate diaphram .
ej2guy21
Oct 4, 2010 02:54 PM
