what turbo
i could be wrong but i dont think that turbo will do it for u. and if it did u would have to beat the hell out of it. go a little bigger than that, maybe a drag kit turbo (T3/T4OE) .53 ar i think. good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red beast »</TD></TR><TR><TD CLASS="quote">what turbo would you reccomend i use on a b18 block with stock sleeve. i have upgraded the pistons and rods looking to make 360-380 hp right now i have a t25 from a 99 esclipe</TD></TR></TABLE>
You arnet gonna make that kinda power out of a T25, Sorry.
360-380 on pump gas i would suggest the SC61.
Everyone and there mother has used it and its been
proven time and time again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B00STFREAK »</TD></TR><TR><TD CLASS="quote">
But it definately Ain't everything, especially if it is a B18A. That turbo is quite the overkill for what he needs in a broad powerband. There are some other choices. Take a look around at what YOU need to accomplish, not just the fact that it "works for everyone". If that were the case, you wouldn't see so many being resold used...
</TD></TR></TABLE>But it definately Ain't everything, especially if it is a B18A. That turbo is quite the overkill for what he needs in a broad powerband. There are some other choices. Take a look around at what YOU need to accomplish, not just the fact that it "works for everyone". If that were the case, you wouldn't see so many being resold used...
