help on turbo selection
Old Apr 1, 2011 | 07:19 AM
PERSIAN_KING_90's Avatar
Icon2 help on turbo selection
hey i have a stock Ls block turbo and the seals on my turbo are shot.. so looking to change or even upgrade the turbo.. from the 50trim 48 a/r i had on it and was making 265 whp and full spool at 8psi, 3600rpm... and my question is should i stick with a 50 trim or should i bump it up a level.?? 54,57,60?? i was thinking about the 60 trim so i wouldn't have to buy another one after rods and pistons ..so wanted to know the pros and cons.. i'm FOB when it come to this stuff so bare with me
Old Apr 1, 2011 | 07:26 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: help on turbo selection
what are your power goals?
Old Apr 1, 2011 | 07:28 AM
we;; before the rods and pistons trying to hit 300 on about 10 pounds and after that looking for around 340-380
Old Apr 1, 2011 | 03:59 PM
TheShodan's Avatar
Moderator
Well don't worry about the boost pressure then. If you want 300, then get 300whp with what you have. There's plenty with what you have to do it. repair and drive.
Old Apr 1, 2011 | 05:15 PM
chialpha2006's Avatar
it took me 20 lbs on a stock ls with a garrett 57 trim .63 a/r to make 300 whp... i was on a blox cast manifold though... i dont have any experience with other turbos but for what you're looking for and my experience, id say its a good option. i never had any complaints with it...
Old Apr 1, 2011 | 05:17 PM
wantboost's Avatar
Who is Mr Robot?
get a new tuner... thats stupid
Old Apr 1, 2011 | 08:10 PM
ironic, because my tuner is nicknamed "st00pid" lol... one of the best tuners in my area... ill never let anyone else touch my car as long as he is around... heres my dyno graph, point out one thing thats "stupid" about it... don't worry- i'll wait... oh yeah went 11.804@120.98, im having trouble finding reasons to get a new tuner
Old Apr 1, 2011 | 09:25 PM
2k.civic.si's Avatar
lol.....wantboost opens mouth sticks in foot.
Old Apr 1, 2011 | 10:10 PM
racebum's Avatar
it's the dyno, 11.8@120 would read more like 380ish-whp elsewhere....unless your car is really light
Old Apr 1, 2011 | 10:17 PM
siblues's Avatar
Your tuner is known for being very good at what he does.I must admit that the numbers and info you gave dont really make sense.Please give a little more info regarding your setup.I would think with that turbo and 20 pounds of boost it would have made a bit more power.
Old Apr 1, 2011 | 10:56 PM
racebum's Avatar
that's what i'm saying. then again when is the last time you ever saw a 300whp teg do an 11.8@120.
between that turbo, the pressure and that ET my guess is really that it's making more than that power level
in other news. OP the 50trim is a great match for that engine. if you wanted a bit more top end with similar to slightly more power dump the .48ar for a .63
Old Apr 2, 2011 | 05:20 AM
wantboost's Avatar
Who is Mr Robot?
lol. you should've just said your tuner was st00pid... he's effing awesome.
with your trap times it definitely sounds like the dyno. has to do with correction method, correction factor, etc i'm willing to bet.
Old Apr 3, 2011 | 11:40 AM
i was thinking i should stick to the 50T and I'm sure I'll be able to hit the 300whp marker with a few more pound of boost....my tuner is known to be one of the best tuners in Toronto so I'm sure he'll be able to get her up there.. idono if you guys herd of him (tony the tiger LMAO ) Dynamotorsports.. i haven't seen a lot of people hit 265 on a stock ls on only 8 psi..so it has to a lot to do with the magic he works...with the 50t don't you think its gonna choke up when i try to hit higher numbers like 340-390..???..s
p.s it took me 20 lbs on a stock ls with a garrett 57 trim .63 a/r to make 300 whp" holy snap.. bro how long did your motor last on 20 pounds i herd the max you should b hitting on stock is 14
Old Apr 3, 2011 | 11:52 AM
TheShodan's Avatar
Moderator
Well, tony should be able to take care of it. We're very familiar with him here and his reputation is uncanny. So you should go for it, and let him decide what boost pressure you'll need to hit your goal. Speculation only brings disappointment, so just let the man do his work.
Good luck to you.
Old Apr 3, 2011 | 05:41 PM
motor lasted about 2 years before something let go in the head which started a chain of events that screwed me over, it was tuned to rev to 7500 and I was beating on it all the time so that didnt surprise me at all, jason had said something would let go in the head before my bottom end let go... and my setup was a blox cast manifold, garrett t3/t4 57 trim .63 a/r, skunk2 intake manifold, 2.5 inch piping with a treadstone tr6 intercooler and rc 550's. only thing done to the motor itself was headstuds to prevent a blown head gasket. here's a vid of me going 11.8@114 when i still had the gsr transmission, since that time i changed to a gsr gear set with ls final drive and that made me pick up 5 mph or so... i ran the 120mph pass twice when jason was there and he messed with the tune a little bit, but theres really no way it was above 325 or so... most it ever dynod was in 50 degree weather and it was 318whp 269tq at Ragin' Racing's DynoJet.
http://www.youtube.com/watch?v=HJNnLFN0l_8
ps. i'm shifting into 5th in this run^^^^... on 24.5" slicks with a gsr transmission, hence the change to gsr gearset with LS final drive...
Old Apr 4, 2011 | 06:22 AM
11.8 thats impressive.. verynice.. but still not understanding how your only at 318.... i thought you would b at at-least 380's nun the less very nice run. allot of the people down here hitting the 300's on like 11-15lbs so i cant wait to see what i pull out ...
Old Apr 7, 2011 | 10:21 PM
anyone els ??
Old Apr 8, 2011 | 08:47 AM
comon guys i'mm getting the turbo thiss week i need infooo lol
jdm_h22
Dec 14, 2011 02:22 PM
SkertySkerty
Jun 6, 2007 08:38 AM
dominikano24
Dec 11, 2005 07:18 PM
itsthatguy
Nov 19, 2004 09:01 PM
gold94accord
Nov 6, 2003 05:22 AM
