17 vac on new boost gauge?
Old Jan 6, 2006 | 09:34 PM
nekoabandoned's Avatar
Default 17 vac on new boost gauge?
just as the title says,i just bought a new autometer boost gauge and now it says 17-18 vac on idle. is this normal with autometer or that?
Old Jan 6, 2006 | 10:14 PM
93civciv's Avatar
Default Re: 17 vac on new boost gauge? (nekoabandoned)
i have an autometer boost gauge and it reads about 20 so i would say your in the normal range.....
Old Jan 6, 2006 | 10:29 PM
boosted k20's Avatar
u have any cams in the motor? with type R cams im idling at like 24 in/Hg. it should be idling higher than 17. whats ur compression ratio
Old Jan 7, 2006 | 01:58 AM
Default Re: 17 vac on new boost gauge? (boosted k20)
stock z6 specs, and i did a crappy valve adjustment a day or twp ago
Old Jan 7, 2006 | 10:31 AM
well theres ur answer. redo the valve lash and it should come back up
Old Jan 7, 2006 | 11:21 AM
turbochargeb18c's Avatar
BANNED
what happens when its reading 10 in/hg....becuase mine is ready at 10 in/hg...id checked everything...did a compresson test(which is good),check for leaks(nothing leaking),change plugs,put new gasket on throttle body,and IM...it was reading 20-23 in/hg bout couple of days ago...havn't drove or touch the car since...
Old Jan 7, 2006 | 11:25 AM
Quad-Damage's Avatar
Default Re: 17 vac on new boost gauge? (turbochargeb18c)
10 u have a leak somewhere keep lookin
mine is at 20 to 21
Old Jan 7, 2006 | 11:29 AM
BANNED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">10 u have a leak somewhere keep lookin
mine is at 20 to 21</TD></TR></TABLE>
yea...id checked it for 3 days now and found nothing...im out if idea where to find the problem...im bout to blow it up...
Old Jan 7, 2006 | 11:41 AM
zexifiedlude's Avatar
whats the best range to be in vac in
Old Jan 7, 2006 | 11:51 AM
tokesGTR's Avatar
Default Re: (zexifiedlude)
Higher = smoother idle and better running power brakes, lower is the opposite. Vaccum at idle is directly related to cam duration (read: overlap) engine displacement, and compression ratio. Higher makes for a smoother running motor. There is no "best range".
Old Jan 7, 2006 | 12:04 PM
mike93eh
Guest
Posts: n/a
i have a z6 with faze boost gauge and it reads 22 at idle.
Old Jan 7, 2006 | 12:13 PM
Adriano's Avatar
Default Re: (mike93eh)
My gsr motor with 9:1 cr idles at 17-18.
Adriano
Old Jan 7, 2006 | 06:52 PM
NuclearB18B's Avatar
Default Re: (Adriano)
my stock b18b with 170k miles reads 22-24 inHg on my defi boost gauge.
Old Jan 7, 2006 | 07:03 PM
1epmugenlude's Avatar
What do you think it should be if you have 8:5:1 compression?
Old Jan 7, 2006 | 08:54 PM
jackhunt321's Avatar
20-22 here
gsrobdi
Feb 21, 2006 06:45 PM
turbochargeb18c
Jan 14, 2006 08:38 PM
ViruSi
Nov 18, 2004 07:47 PM
Eskay@JDMCircle.com
Oct 6, 2004 09:43 PM
threatcon13
Feb 3, 2002 01:23 AM
