98 ek motor into 92 eg?
Old Jan 6, 2006 | 03:02 PM
BackupNyou's Avatar
Default 98 ek motor into 92 eg?
I have a 92 EG and a chance to get at D16z6 outta a 98 EK for cheap and i wanted to know if its a possible swap with in reason, or is there major fab needed?
Modified by BackupNyou at 4:24 PM 1/6/2006
Old Jan 6, 2006 | 06:45 PM
BackupNyou's Avatar
Default Re: 98 ek motor into 92 eg? (BackupNyou)
bump^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Old Jan 6, 2006 | 06:47 PM
egvtec's Avatar
do you mean a d16y8? or did someone swap a z6 into a newer coupe?
d16y8 is factory in a 96 up civic ex coupe. d16z6 came in delsol Si's and 92-95 civic hatches. and in ex 4dr and coupes.
Whichever motor its not too bad i know alot of people with y8 motors in their eg's
the easiest way is to cut the obd2 plug off the distributor and sauder on the obd1 plug wires so that you can swap an obd1 engine harness and it all plugs up except that you will need obd1 injectors so the harness fits, cause obd2 injector clips are different. just use a p28 and an obd1 header that has only one o2 bung and your golden
Old Jan 8, 2006 | 11:40 AM
BackupNyou's Avatar
Default Re: 98 ek motor into 92 eg? (egvtec)
Its a D16z6 outta a 98 hatch, i think its OBD1 but was spliced to 2 for the EK, its boosted and i have basically the front clip so i have everything that i need just dont know if it will drop right in, it should, and the ecu came with hondata s200 so im hoping everthing plugs in fairly simple.
Old Jan 8, 2006 | 11:44 AM
.Beaver's Avatar
Bloody Beaver
theres no reason why it wouldnt bolt in. I wouldnt go through all that work if it was boosted on stock internals. It's just a ticking time bomb
Old Jan 8, 2006 | 12:56 PM
BackupNyou's Avatar
Default Re: 98 ek motor into 92 eg? (.Beaver)
I think there is dif internals cuase i rode in the EK just before we took the motor out and it pulled hard and ran nice, who knows tho
Old Jan 8, 2006 | 01:21 PM
.Beaver's Avatar
Bloody Beaver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BackupNyou &raquo;</TD></TR><TR><TD CLASS="quote">I think there is dif internals cuase i rode in the EK just before we took the motor out and it pulled hard and ran nice, who knows tho</TD></TR></TABLE>
that doesn't mean ****. It was turbo'd on hondata so of course it pulled nice and ran good. I still wouldn't trust the motor unless it was documented as being built
martiniracing
Dec 10, 2009 05:54 AM
kaoticstyles
Jun 20, 2008 03:30 PM
EGhatch33
Jan 12, 2007 09:54 AM
kevbo82
Jul 21, 2005 03:16 PM
JdmEg6Hybrid
Apr 15, 2004 09:12 PM
