obd1 b-series into 98 civic
Now i have an obd1 grs swaped in my eg and I'm swapping it into my 98 hatch what do i need to swap it in? I know i need motor mounts and obd1 to obd2 conversion harness, but is there any thing else i need?? is my ek obd2a obd2b?
Re: obd1 b-series into 98 civic (JdmEg6Hybrid)
Being that it's a 98 it should be obd2a. You'll have to do wiring again. the hatch engine harness needs lot-o-work to work. Or get an EX engine harness and do very little. The distributor, injectors and alternator have to be changed to obd2 unless you change the plugs and stuff too. Just did a 94 LS into a 96 CX.
Re: obd1 b-series into 98 civic (Cvic90)
he is right:
In ur case since u have an OBD1 Motor u gotta change the plug on the Dizzy itself to OBD2 Plug, change injector plugs to OBD1 or just put in OBD2 injectors and u will have to get an OBD1 alternator plug and tap it on ur 98 harness to work with ur 94 alternator.
If u need em I have an OBD2 Distributor Side Plug, OBD1 alternator plug and the OBD2 B16a2 Injectors lemme know
