Washer and Bolt Camber trick Went back
Old Jan 5, 2006 | 06:12 PM
A.E Motoring's Avatar
Default Washer and Bolt Camber trick Went bad
the 2 holes where the bolts go, one of the wholes is pretty much Fuucked, the threads are so bad, that when i try to put the bolt in, it just eats up all the threads, and then there was a time where i couldn't get the bolt back out, it just spun, so now its just being held by one bolt, anyone know how to fix this? i refuse to drive my car and put my self in danger. i was thinking of using a tap, but not sure how to get the tap in there with everything in the way, TIA
Old Jan 5, 2006 | 06:23 PM
Lord Helmet's Avatar
Default Re: Washer and Bolt Camber trick Went bad (SPNFEDEJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ &raquo;</TD></TR><TR><TD CLASS="quote">the 2 holes where the bolts go, one of the wholes is pretty much Fuucked, the threads are so bad, that when i try to put the bolt in, it just eats up all the threads, and then there was a time where i couldn't get the bolt back out, it just spun, so now its just being held by one bolt, anyone know how to fix this? i refuse to drive my car and put my self in danger. i was thinking of using a tap, but not sure how to get the tap in there with everything in the way, TIA</TD></TR></TABLE>
Well this what I did when I had a stripped thread hole. I drilled out the hole and bought a coil spring (auto shops will have it), find the specs on the thread size and reinsert the coil spring back in with the supplied thread locker. I've done this on countless stripped holes that were rusted to hell or stripped due to past idiot technicans over torquing them.
Old Jan 5, 2006 | 08:04 PM
anyone else?
Old Jan 5, 2006 | 08:08 PM
brusk13's Avatar
drill tap insert helicoil - properly done so read instructions
Old Jan 5, 2006 | 08:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ &raquo;</TD></TR><TR><TD CLASS="quote">anyone else?</TD></TR></TABLE>
there's nothing else! that's what you need to do, get a helicoil and tap into the hole.
spidermancivic
Aug 11, 2007 08:17 AM
EFstyle
23
Jan 27, 2007 10:49 PM
blackdc5
Welding / Fabrication
13
May 9, 2006 11:21 PM
Layziebtnh055
May 14, 2004 06:42 AM
GDM Z28
Mar 1, 2004 07:53 AM
