Honda S2000 Honda S2000
Interested in gettin an S2000 got a couple of questions??
Old Jan 5, 2006 | 09:50 AM
DeDonDeRosa's Avatar
Default Interested in gettin an S2000 got a couple of questions??
delete
Old Jan 5, 2006 | 09:54 AM
Francesco's Avatar
Default Re: Interested in gettin an S2000 got a couple of questions?? (DeDonDeRosa)
s2000 is made to take a beating, just sometimes people over due it...
theit good cars, you should be more worried about a diff blowing than your motor
Old Jan 5, 2006 | 10:02 AM
Mr. Projekt's Avatar
* B A N N E D *
I've seen 2 cases of retainer failure. One was overrev while boosting, the other was screwed on a car he just bought. As far as diff housing failure, it due to excessive beating of the car combined with soft/worn diff mounts, or inversely, solid ones.
Honda complete diagnostic. If the car has over 36k miles, pull the head. Only way to be sure.
Old Jan 5, 2006 | 11:11 AM
TL1000R's Avatar
Default Re: Interested in gettin an S2000 got a couple of questions?? (Slideways2000)
My question is, what is Honda's definition of over-revving?
Old Jan 5, 2006 | 11:23 AM
* B A N N E D *
Default Re: Interested in gettin an S2000 got a couple of questions?? (TL1000R)
The ECU records shift-points with speed/rpm logged. It's up to interpretation from the mechanic.
Old Jan 5, 2006 | 11:35 AM
what years do the diffs go bad ??? all?? is there a way to prevent it?
Old Jan 5, 2006 | 11:45 AM
* B A N N E D *
No specific years. They usually go bad due to operator error, though very few will admit it. I've tracked my car countless times last year, including a couple of 1/4 runs, and it held up fine.
To clear it up, it is not the diff that goes bad. When the housing is exposed to excessive shock/stress, the diff itself gets pushed out of the rear housing, taking the side bearings with them. The Comptech housing reinforces the bearing groove. That's it.
Old Jan 5, 2006 | 12:09 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
The biggest thing is to avoid big clutch drops. The easiest way to toast the diff is dropping the clutch at a high rpm.
Old Jan 5, 2006 | 12:20 PM
WowOzYouRock's Avatar
Default Re: Interested in gettin an S2000 got a couple of questions?? (NAallTheWAY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAallTheWAY &raquo;</TD></TR><TR><TD CLASS="quote">The biggest thing is to avoid big clutch drops. The easiest way to toast the diff is dropping the clutch at a high rpm.</TD></TR></TABLE>
low rpm ... when you drag you need it drop it in high RPM to let the tire spin ... i know some people drop it on 7000
Old Jan 5, 2006 | 01:04 PM
EFSS153
Default Re: Interested in gettin an S2000 got a couple of questions?? (Y2K_S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">
low rpm ... when you drag you need it drop it in high RPM to let the tire spin ... i know some people drop it on 7000</TD></TR></TABLE>
There's a difference in easing off the clutch in drag racing and dropping the clutch. Dropping the clutch at high RPMs will damage the diff.
Old Jan 6, 2006 | 06:44 AM
cause im looking at an 02 w/ 13k miles on her
Old Jan 9, 2006 | 11:26 AM
bump
Old Jan 10, 2006 | 07:51 AM
al4t1gbundy's Avatar
There's a difference in easing off the clutch in drag racing and dropping the clutch. Dropping the clutch at high RPMs will damage the diff.</TD></TR></TABLE>
Wait ... can someone clarify this. I mean so when you launch, slip off teh clutch at high rpms so the tires spin? I read that you actually drop the clutch (ie let it out as fast as you can) so the tires spin .....
DeLorean00
Honda S2000
Nov 24, 2013 04:24 AM
bCzirr
Honda S2000
55
Jul 14, 2010 07:13 PM
djnikko
Honda S2000
Feb 5, 2004 01:46 PM
TimN88
Honda S2000
Nov 24, 2002 07:42 PM
Turbo Lude SH
Honda S2000
14
Nov 23, 2002 02:28 PM
Top
Follow Us
