Where to get coolant and steel braided lines?
Where can I get any type of coolant line for my gt35r? its a 3.8 pushlock fitting. Im just wondering where I can get the exact blue line like in this picture?
Also. I am running a top mount setup where as the oil drain hose will be near the manifold and alot of heat. What type of oil drain hose is the best for this application?
Modified by endlessdv at 7:22 AM 1/5/2006
Modified by endlessdv at 8:14 AM 1/5/2006
you can get lines and fittings like that through stan...if i am correct the new site is still in the works...his user name is flamenco-t.
an alternative option - jeff evans also has a stainless steel water line kit for gt-series turbo's, sales@evans-tuning.com. im running these personally on my setup, they make for a very clean install, less worry about heat and leaks, and include everything you need.
Modified by yehiknowrite at 1:10 PM 1/5/2006
Modified by yehiknowrite at 1:11 PM 1/5/2006
http://www.bakerprecision.com/aqp1.htm
not sure if these are the exact same, but they might be close
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitownrida »</TD></TR><TR><TD CLASS="quote">i know this is gonna turn into a stan vouch thread. but for good reason
stan@fast-turbo.com</TD></TR></TABLE>
From: That's the wrong tone... I'm Skunk2 certified.
FlyZlow
Jun 7, 2005 05:45 PM
igo4bmx
May 1, 2003 01:08 PM
