water leaking into my trunk
Old Jan 3, 2006 | 07:35 AM
Thunder Cat's Avatar
Default water leaking into my trunk
if you have a picture of a cb7's inside trunk,post it up for me so i can describe the problem in more detail. i'll hightlight the points or whatever. my cam is missing so bare with me.
facing the trunk with the lid up you'll notice the carpet in there is damp. the whole left and right side(along the wall)is a literal river and i cant tell where the water is getting through. help me out guys,***** starting to stink up the ride and seep into the back seats!
gimme suggestions and solutions please
Old Jan 3, 2006 | 07:58 AM
P_Adams's Avatar
Default Re: water leaking into my trunk (Thunder Cat)
Either the corners of the rear glass or the outboard tail Lamps are leaking.
Take off the rear inspection panels and run water over the lamps. If you see water coming in, the tail lamp gaskets need to be replaced.
If it leaks from the rear glass, it will need to be resealed / reset
P
Old Jan 3, 2006 | 08:46 AM
alright,its raining right now so i'll check that tail lamp out though. but how can i be sure if its my rear glass?
Old Jan 3, 2006 | 08:49 AM
P_Adams's Avatar
Default Re: (Thunder Cat)
If there are trim panels in the way, you may have to remove some to uncover where you have to look. In extreme cases, it literally rains inside the trunk.....
P
Old Jan 3, 2006 | 09:27 AM
i opened up the covers in the trunk for the tail lamps and noticed moisture in there. used the good ol' dry finger and came back with dirt and wetness on it too,so im guessing yeah my tail is leaking. but i'll continue to check for other areas incase they contribute to my pool
Old Jan 3, 2006 | 11:10 AM
P_Adams's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thunder Cat &raquo;</TD></TR><TR><TD CLASS="quote">other areas incase they contribute to my pool</TD></TR></TABLE>
Or maybe the Ice Skating Rink in the Spare Tire Well
P
Old Jan 3, 2006 | 11:16 AM
lol
Old Jan 3, 2006 | 12:44 PM
zigzack's Avatar
Kinda funny, I'm having the same exact problem, and there is a lot of water on the inside of my tail lights, you might alos want to check your antenna hole, like where it pokes through the body, especially if its an aftermarket one, my trunk leaks a little there too, also I've seen early 90's hondas have trouble with the trunk weatherstripping.
Old Jan 3, 2006 | 01:27 PM
P_Adams's Avatar
Default Re: (zigzack)
You're a candidate for not only resealing the lamps to the body, but the lamps themselves. Clear GE silicone sealer will work fine.
P
Old Jan 3, 2006 | 03:56 PM
Honda-Master's Avatar
replace the gasket for the outer tail lite assembly,,,,,,they are made of foam rubber and over the years they crack and allow water to get in trunk and tail lite assembly......gaskets cost about 8 dollars each from dealer ,,,,,,also put a beed of honda -bond all the way around above the gaskets on the trunk body.. you need a 8mm socket to remove the nuts ( 5 ) ,,very easy job
Old Jan 3, 2006 | 04:28 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thunder Cat &raquo;</TD></TR><TR><TD CLASS="quote"> my cam is missing so bare with me.
[QUOTE]</TD></TR></TABLE>
Would it be okay if we 'bear' with you LOL
Old Jan 3, 2006 | 04:44 PM
zigzack's Avatar
Thanks honda master for the prices, but I work at an auto shop, so I know how to change a tail light fixture . And thanks P_adams for the silicone recomendation.
Farquea
Nov 9, 2018 05:00 AM
thewrai6th
Feb 17, 2017 09:50 AM
citrus3000psi
May 19, 2008 02:52 PM
x1aO
Mar 10, 2008 01:02 PM
illusion
Dec 11, 2004 08:21 PM
