vtec not working
Old Jan 2, 2006 | 08:57 PM
Shake and Bake's Avatar
Default vtec not working
I have a 98 ex coupe and vtec isnt working. Where should i start troubleshooting at? Iv searched but alot of the words used are too technical for me so take it easy on me. Thanks for any help.
Old Jan 2, 2006 | 08:59 PM
Hercules's Avatar
Default Re: vtec not working (AllstockSIke)
Make sure your vss works, check your oil, and do you have a CEL? Faulty wiring?
Old Jan 2, 2006 | 09:03 PM
Sloshy's Avatar
Default Re: vtec not working (Hercules)
make sure ur tack works, all wires are hook up correctly oil presuure is good and you have the right ECU<- i seen it happen
Old Jan 3, 2006 | 01:11 AM
sitinthehall's Avatar
Make sure you have a Vtec motor . Other than that anything that has to do with oil pressure, rpm, speed, and temperature could affect your vtec. I had some wiring go bad that went to my vehicle speed sensor once.
Old Jan 3, 2006 | 01:52 PM
How can i find out that i have a vtec motor? I checked online and it says that the model civic i have has vtec. But on my friends civic that has vtec it says it on the motor and not on my motor.
Old Jan 3, 2006 | 02:02 PM
IHateJDM's Avatar
Default Re: (AllstockSIke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllstockSIke &raquo;</TD></TR><TR><TD CLASS="quote">How can i find out that i have a vtec motor? I checked online and it says that the model civic i have has vtec. But on my friends civic that has vtec it says it on the motor and not on my motor.</TD></TR></TABLE>
look for your engine code (in front of motor, near tranny, under dizzy). for a 98 ex, it should be d16y8 which is a vtec motor. How do you know vtec isn't working? with a stock intake, its hard to tell on a single cam.
Old Jan 3, 2006 | 02:04 PM
Tad's Avatar
Tad
98ex coupes do have vtec.
is your car all stock or has it been modified at all?
does your CEL light come on at all?
And what makes you say your vtec isn't working in the first place???
Are you sure you know how your engine should feel with vtec working?
Old Jan 3, 2006 | 02:54 PM
Yes, i know its not working im not that retarded. And i know how vtec sounds, i heard it before on friends cars. Plus my car isnt stock i have a v2 cold air intake, and skunk catback exhaust. Thanks for anymore help
Old Jan 3, 2006 | 02:55 PM
Tad's Avatar
Tad
no CEL ??
also vtec sounds different on different engines,
it's almost inaudible on sohc engines(urs) and it's very loud/noticeable on integras/dohc engines.
Old Jan 3, 2006 | 02:58 PM
which cel are you talking about? sorry if thats a dumb question.
Old Jan 3, 2006 | 03:01 PM
97spooncivic's Avatar
with just an intake, your not gonna be able to hear or feel vtec on a sohc. as long as you have so cels, that your vtec is working. make sure your engine is warmed up, enough oil pressure and oil itself,and your going fast enough (ie over 25 mph). I had to put exhaust, intake, header, cam, just to hear my vtec. and i can barely hear it and i dont even feel it
Old Jan 3, 2006 | 03:41 PM
Default Re: (Tad)
A cel is when the check engine light comes on. It will throw a code number. Then you need to figure out what is making the check engine light come on. If it is on, I would recommend taking it to auto zone or oreilys and they will read it for you.
Old Jan 3, 2006 | 04:15 PM
pennies_hatchie's Avatar
Default Re: (sitinthehall)
why dont you look @ my old vtec thread and see if it helps you, i still have NO VTEC
https://honda-tech.com/zerothread?id=1411682
Old Jan 3, 2006 | 05:39 PM
nekoabandoned's Avatar
Default Re: (pennies_hatchie)
1 tear and i still cant get vtec lol good luck
Old Jan 3, 2006 | 06:20 PM
b18c1cx's Avatar
who cares, your car is slow anyways, so vtec wont do anything to help. get a swap. haha
Superfly94
Sep 5, 2007 09:55 AM
rev_it
Apr 12, 2006 12:01 PM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
b16mike
May 13, 2005 09:51 PM
Ch3mik
20
Mar 30, 2005 11:56 PM
