Misfiring on Zex 75 shot Dry need help
Old Jan 2, 2006 | 04:37 PM
blazin99si's Avatar
Default Misfiring on Zex 75 shot Dry need help
99 b20, MSD cap, external coil, 1 degree colder plugs, timing retarded 4 degrees
New distributor rotor, p75 ecu
All motor its fine but backfires & misfires once I start spraying Any help/suggestions on this??
Old Jan 2, 2006 | 05:16 PM
97hb's Avatar
Default Re: Misfiring on Zex 75 shot Dry need help (blazin99si)
Make sure your plugs are gaped right. Could also be a weak coil.
Old Jan 2, 2006 | 06:21 PM
Phase Change Racing's Avatar
Does it just pop upon activation or does it just pop and fart as long as the system is activated?
Dry systems are usually pretty slow to react on the fuel side which can cause a lean surge upon activation. If its crapping out for more than half a second you have bigger problems. What is your fuel pressure before and after activation? What bottle pressure are you running? How do the plugs look after you try to use the bottle?
Old Jan 2, 2006 | 09:29 PM
blazin99si's Avatar
Default Re: Misfiring on Zex 75 shot Dry need help (97hb)
Factory gap on plugs, Ive been spraying for over a year now and have had no problems until today when I installed a Zex bottle heater and retarded the timing. Pressure on the bottle is 910-930 consistent, fuel pressure b4 spray is 38psi, dont know during spraying though. It basically misfires all the way up to about 6-7k. Ive also got RC 310s and an afc. The plugs are all consistent--grayish/light white. I checked the plug wires, the MSD coil itself is about 6 months old maybe my fuel pumps bad?? Ive noticed with the car idling I'll pull on the throttle pulley to accelerate and the fuel pressure goes down. B&M fpr. Thanks for the suggestions/input so far guys cuz Im stumped keep em coming please!!
Old Jan 2, 2006 | 09:38 PM
Ya, sounds like you may have a fuel pressure problem to me. Try to make a quick burp on the bottle and keep an eye on your fuel pressure and see what its doing.
Old Jan 2, 2006 | 09:49 PM
blazin99si's Avatar
Default Re: Misfiring on Zex 75 shot Dry need help (Phase Change Racing)
Thanks bro Ima check on that, any other suggestions go right on ahead
Old Jan 3, 2006 | 12:13 AM
D@nnY's Avatar
I believe the zex kits regulate fuel based on bottle pressure.....the more pressure they have the more fuel they will add...the bottle heater will casue more pressure
deff get a wideband on that thing
JDMDC4life
Oct 12, 2006 02:18 PM
Lude_Behavior_97
Sep 2, 2004 08:43 AM
98Kord
Jun 26, 2003 07:23 AM
tmekjian
Jun 11, 2003 11:35 AM
whatVTEC
Sep 15, 2002 06:06 PM
