Top Mount and Full Size Radiator??
Old Jan 2, 2006 | 05:19 PM
wantboost's Avatar
Who is Mr Robot?
Default Top Mount and Full Size Radiator??
i was just wondering if this was possible, im looking into a topmount now and was curious if space was allowed for a full length radiator? car is a 99 em1, built ls.vtec
Old Jan 2, 2006 | 05:27 PM
B18 CYA's Avatar
man u have a mixed up mind...make up ur mind! before u said ur not boosting anymore
Old Jan 2, 2006 | 05:30 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (B18 CYA)
no im not working on my em1 for right now, im just gonna lay back and re evaluate my plans. im getting a del sol to drive hopfully, so i can take my mind off of everything that has happened and my em1. the built motor will be going in the sol temporarily
Old Jan 2, 2006 | 06:19 PM
TurboCoop's Avatar
Default Re: (wantboost)
Im sure you know more than me but I think all the top-mount setups Ive seen were no where near being able to fit a full size rad. You are probably using a big turbo too so I dont think it would work.
Old Jan 2, 2006 | 06:30 PM
asianpoet's Avatar
Default Re: (TurboCoop)
how good are you at fabricating?
You have to move your radiator to the front. make custom brackets, (might as well make a traction control bars) and mount it there...
Old Jan 2, 2006 | 06:40 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (asianpoet)
l-con does all of my fabwork.
i had thought about just dropping inbetween the upper and lower rad supports.... im using an lines for the coolant... just debating between 12 or 16an
Old Jan 2, 2006 | 10:37 PM
wantboost's Avatar
Who is Mr Robot?
ok, so how bout a half side rad... or so...
29 3/4 WIDE, 22 1/4 TALL, 4" DEEP
i figure this would work nicely, i need to go measure and see if its small enough to set in between the upper and lower rad supports
Old Jan 2, 2006 | 10:46 PM
This One's Avatar
If your putting it in a Del Sol, How come your worried about a Full-size Radiator?
Old Jan 2, 2006 | 10:52 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (This One)
eh, its in a sol temporarily (that is, if i even get a del sol)
but regardless it will be going in a 99em1... i want the larger rad because of cooling.. where i live is pretty damn hot during the summer months and im no grandma behind the wheel
Old Jan 2, 2006 | 11:04 PM
This One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">eh, its in a sol temporarily (that is, if i even get a del sol)
but regardless it will be going in a 99em1... i want the larger rad because of cooling.. where i live is pretty damn hot during the summer months and im no grandma behind the wheel</TD></TR></TABLE>
Ah ok, well just a though, I'm sure its nice to have the extra assurance of the bigger raditator, but you can easily get away with the half size.
We use them on just about everything we build, wether honda or not.
Daily driven cars here in texas, we dont seem to have much of a problem.
Old Jan 2, 2006 | 11:05 PM
wantboost's Avatar
Who is Mr Robot?
true, but i can get the full core a whole hell of a lot less than a half core (200 shipped for a C&R/Visteon Racing with a heat exchanger, etc)
Old Jan 2, 2006 | 11:09 PM
This One's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">true, but i can get the full core a whole hell of a lot less than a half core (200 shipped for a C&R/Visteon Racing with a heat exchanger, etc)</TD></TR></TABLE>
True, but then you run into a manifold not being compatible
Its a trade-off
Old Jan 2, 2006 | 11:15 PM
wantboost's Avatar
Who is Mr Robot?
true, but if i set it back in between the rad. supports then it wont be an issue, it wont even stick out as far as an oem half size...
Old Jan 3, 2006 | 12:31 AM
andysila's Avatar
you wont have any problems
raverx3m
May 19, 2011 10:54 AM
JacksonD
Feb 16, 2010 03:31 PM
SmoothLude
May 16, 2009 03:04 PM
MooreBoost
Oct 25, 2004 03:07 PM
4wsB21a
Jul 11, 2002 08:36 PM
