Benefits of water cooled turbo?
Old Jan 1, 2006 | 08:53 PM
endlessdv's Avatar
Default Benefits of water cooled turbo?
The turbo i ordered came with both oil and water cooled. I was planning on just running oil through it. But are there any benefits of making it water cooled too?
Old Jan 1, 2006 | 08:57 PM
slowteg550's Avatar
Default Re: Benefits of water cooled turbo? (endlessdv)
Run the water cooling option too, it greatly reduces heat. It'll help your turbo's efficiency range, and keep air temps down a bit, along with being safer on the turbo.
Old Jan 1, 2006 | 08:59 PM
Boilermaker1's Avatar
And when you shut the car off, the water keeps flowing through it just by the fact that its a hot spot with cooler water running through it. The water will continue to move without the pump on, helping lessen the heat soak.
endlessdv's Avatar
Default Re: Benefits of water cooled turbo? (slowteg550)
In that case. Anyone know where I can buy elbow water fittings for the GT35R? Or any idea on what size threading they are? Also the tubing. Any idea on where I can get high temperature hoses for the water lines? thanks
Old Jan 1, 2006 | 09:03 PM
atpturbo.com sells fittings for all the GT series turbos. mine (28R) are 16mm threads for banjo bolts and the banjo fitting has a 1/4 NPT on it with the suggestion of -6 lines, the 35R may have bigger ones.
High temp hoses can be SS braided, rubber, the Twist-Lok type hoses, etc..... water's not that hot, you can use whatever your hose material of choice is from summit, jegs whatever.
Old Jan 1, 2006 | 09:18 PM
EK k kay's Avatar
Default Re: (Boilermaker1)
I'm sure that on all Garrett GT series ball bearing turbos it's required to run both oil and water to cool down the turbo.
Old Jan 1, 2006 | 09:19 PM
BlueLude94's Avatar
It keeps you from having to use a turbo timer, but you can still get one so people can tell you "Hey, you left your car running!"
Old Jan 1, 2006 | 10:15 PM
endlessdv's Avatar
Default Re: (BlueLude94)
http://www.atpturbo.com/Mercha...e=FTG
If I got two of those on both sides of the turbo for in and out. and run hoses with clamps. Would that work well?
bob102386
Sep 16, 2021 07:36 PM
dryhopsux13
Sep 29, 2004 05:39 AM
Jamison
Jun 27, 2002 11:37 AM
Brian_92GSR
Apr 9, 2002 07:21 PM
