Rear main seal!!!!!
Old Jan 1, 2006 | 08:28 PM
JDMPower98cp's Avatar
Default Rear main seal!!!!!
Ok so my car is leaking oil in between the motor and tranny im guessing its the rear main seal!!! ouch any suggestions and on how to do it.. The car is a 98 honda civic HX d16y5..anything would help thnx..
Old Jan 1, 2006 | 08:30 PM
coquitlamEG's Avatar
Default Re: Rear main seal!!!!! (JDMPower98cp)
Only one way to do it. Take the engine out, remove the flywheel and change the seal.
Old Jan 1, 2006 | 08:41 PM
Default Re: Rear main seal!!!!! (coquitlamEG)
i was thinking abt removing the tranny then the clutch and flywheel...does it require any internal work or is it on the outside????
Old Jan 1, 2006 | 09:15 PM
Luserkid's Avatar
You dont need to pull the whole motor to get it.
Remove tranny
Remove clutch
Remove flywheel
Remove oil pan
Remove rear main seal
Replace RMS
Put back oil pan
Put back Flywhel
Put back clutch
Put back tranny
Have a beer.
If its your first time have a weekend set aside to do it.
Old Jan 2, 2006 | 12:11 AM
Earthworm Jim's Avatar
Default Re: Rear main seal!!!!! (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">You dont need to pull the whole motor to get it.
Remove tranny
Remove clutch
Remove flywheel
Remove oil pan
Replace RMS
Put back oil pan
Put back Flywhel
Put back clutch
Put back tranny
Have a beer.
If its your first time have a weekend set aside to do it. </TD></TR></TABLE>
All of that is a pain in the rump but it's needed
89bluehatch
Mar 3, 2007 12:53 PM
Ricey McRicerton
Sep 17, 2005 09:53 PM
Do_Ster
Jan 14, 2005 08:23 AM
0ptimus prime
12
Jul 18, 2004 01:29 PM
Lei Siew Long
Aug 19, 2001 05:35 PM
