Cell Code 22 - What to fix?!?
Old Mar 19, 2002 | 03:59 AM
typer_801's Avatar
Default CEL Code 22 - What to fix?!?
I pulled my CEL code last night and it came up with "22".
I've had the car at the dealer a couple of times for the same code and they said nothing was wrong and reset the light. The CEL is now tripping at least once per time I drive the vehicle and I'm losing VTEC everytime that happens (unless I shut the car off and then turn it back on).
My question is what should I look to check or replace? The C-Speed Racing site says it a "VTEC Oil Pressure Switch", but the dealer allegedly tested it and said it was fine. Is that the likely culprit or is it something else? TIA.
[Modified by typer_801, 8:08 AM 3/19/2002]
Old Mar 19, 2002 | 06:06 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: CEL Code 22 - What to fix?!? (typer_801)
22 is VTEC system failure code. It can be the pressure switch, vtec sol, ECU and I think one other item.. check oil level first since it doesn't seem to happen instantly.
Old Mar 19, 2002 | 06:50 AM
BoM's Avatar
BoM
Default Re: CEL Code 22 - What to fix?!? (FL n NC rock j00)
yeah i got that too, i was kinda low on oil, filled it up. code never pops up again though.
but whenever i short the service connector, that same CODE 22 comes up!
Old Mar 19, 2002 | 07:08 AM
typer_801's Avatar
OK, I religiously check the oil level and it was within the acceptable range (middle of the marks) when I checked it last fillup. At that, I'm getting the CEL code daily.
Dealer checked the VTEC solenoid last time in and it was fine, but I don't remember about the any pressure switch, or further tests they did. Looks like I may have to consult the Bentley....
I will top the oil off tonight and see if that makes a difference before I get too involved though.
integracivic94
Aug 22, 2004 08:42 AM
McNizzle
Apr 28, 2004 05:44 AM
endlesswinterco
Jan 10, 2004 01:26 PM
spoonfedGSR
Sep 26, 2003 02:31 PM
DuNkiN
Sep 30, 2002 08:26 PM
