engine code 13
Old Mar 18, 2002 | 06:46 PM
Eg6_JDM's Avatar
Default engine code 13
i got an engine code 13 BARO - atmospheric pressure sensor......anyone know where this is located......and any posible way to fix this......thanks
Old Mar 19, 2002 | 03:59 AM
EE_Chris's Avatar
Default Re: engine code 13 (anger)
This sensor is usually located IN the ECU.
The ECU uses this sensors output, along with MAP output, to arrive at the true manifold pressure.
If the sensor is bad...its time for a new ECU. But try resetting the ECU as anger suggested to see if it comes back.
Old Mar 19, 2002 | 07:40 AM
Eg6_JDM's Avatar
Default Re: engine code 13 (EE_Chris)
Thanks ill try that
Old Mar 19, 2002 | 11:56 AM
Perfectionist's Avatar
""This sensor is usually located IN the ECU.""
FWIW, the PA sensor on my Civic is located above the passenger side kick panel, just above the diagnostic connector.
Old Mar 19, 2002 | 12:27 PM
EE_Chris's Avatar
Default Re: engine code 13 (Perfectionist)
On earlier models, the BARO sensor was seperate from the ECU....however, the poster did not say what his ride was.
Guess I should have added that too. Thanks for the clear up.
Old Mar 19, 2002 | 01:35 PM
Eg6_JDM's Avatar
i have a b16a w/P30.....have to replace vtec solenoid and then reset ecu......ill let you guys know......thanks a lot
roy ezechukwu
Feb 6, 2014 02:13 PM
Hgoku10
Aug 4, 2009 09:05 AM
bmoua
Apr 15, 2007 12:24 AM
SlippylesKB
Nov 15, 2003 12:06 PM
.brad
Jan 21, 2002 02:01 PM
