Toda B'ers...what size injectors do u run
quote:
Stock fuel system(injectors, pump,rail), V-AFC,FPR, Tuned ECU
same, minus the FPR
, think it helps?
same, minus the FPR
, think it helps?
PowerFC/Hondata and 440's...that's all you need, no FPR, no VAFC, no fuel rail. It worked for me for quite a while.
Now Dino do you need a set of 440's
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
what else have u done to the fueling system...ie fuel rail, pump, etc
stock pump and injectors with chipped ECU, AEM FPR and VAFC for now. May upgrade to Prelude injectors if the AEM FPR is not enough the bring most of the setting on the VAFC back to the - ive side.
Drinker
