idle problem rolling my eyes
Old Dec 29, 2005 | 08:46 PM
bleedblue94's Avatar
Default idle problem rolling my eyes
ok i have a b16 block with a gsr head and itr tranny running off a jdm p30. butterflies have been removed from the manifold. motor ran fine when i put it in...after awhile it developed this bogging idle when it warms up. it comes and goes. car idles fine till it warms up then sometimes as its idling at 700 rpm it putts and boggs alittle to 600 or 650 but its not the speed thats concerning me ... its the putt noise it make just was it boggs. ive also noticed there seems to be a very slight sputter in the idle when its not doing this. ive tried a couple good dizzys and a different ecu but i still have the same problem....please any help
Old Dec 30, 2005 | 07:42 AM
Default Re: idle problem rolling my eyes (bleedblue94)
anyone have any ideas?
Old Dec 30, 2005 | 09:14 AM
streetracerof06's Avatar
mine is doing the same thing, so if anyone has some info please let us know. free bump
Old Dec 31, 2005 | 10:43 AM
Default Re: idle problem rolling my eyes (streetracerof06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracerof06 &raquo;</TD></TR><TR><TD CLASS="quote">mine is doing the same thing, so if anyone has some info please let us know. free bump</TD></TR></TABLE>
im sure someone has this problem before whos fixed it......
Old Dec 31, 2005 | 04:07 PM
bump
Old Dec 31, 2005 | 04:55 PM
Stingray96's Avatar
no idea.....but someone might chime in, free bump to you....it might be dirty injectors but i dont nkow....
Old Dec 31, 2005 | 05:05 PM
Tippyman's Avatar
Try reconnecting the butterfly. I doubt that it the problem. IACV maybe?
Old Dec 31, 2005 | 05:14 PM
Default Re: (Tippyman98)
its not the butterflies bc i had no problem without them for quite a while....ive tried cleaning the iacv...i may just go ahead and replace it
Old Dec 31, 2005 | 05:15 PM
nekoabandoned's Avatar
i cleaned my map sensor and iacv worked like a charm,if it doesnt work at least itll only take a minute or two to do.
Old Dec 31, 2005 | 05:18 PM
Handle The Business's Avatar
Try to clean the screen on the fitv. if the problem still occurs make sure your coolant system has no air in it.
Old Jan 1, 2006 | 02:56 PM
Default Re: idle problem rolling my eyes (Handle The Business)
bump
Old Jan 1, 2006 | 03:51 PM
eg6_rick's Avatar
any CELs? if not then clean iacv and map. I'm sure something along those sensors are making the bogging idle. I had an OBD2 LS in my 93 hatch was doing the same thing, I had to reconnect all sensors on the mani and replace broken connectors worked like a charm my bogging idle was no more. Hope this helps.
-Rick
Old Jan 1, 2006 | 10:22 PM
Default Re: idle problem rolling my eyes (eg6_rick)
no cels...i have no damaged plugs or anything like that....ill try swapping the map out for a known good one
Old Jan 4, 2006 | 10:05 AM
ttt
rayray NOT shanaynay
Apr 26, 2007 04:19 AM
bleedblue94
Jan 4, 2006 10:05 AM
Shmolie
Jun 29, 2005 05:58 PM
Cruzan77
12
Mar 3, 2005 07:32 PM
quik2kSi
Dec 27, 2003 09:04 AM
