b16 tranny on ls motor
Old Dec 29, 2005 | 09:11 AM
a2dadamm's Avatar
Default b16 tranny on ls motor
i herd the b16 tranny is better on the ls motor than the ls tranny what exzactley does it help with..... i do alot of highway travel and when i crusin at like 80 im at 4 grand will a b16 tranny reduce that and make it better on top end ???????? thanx
Old Dec 29, 2005 | 09:24 AM
TRE_'s Avatar
Default Re: b16 tranny on ls motor (a2dadamm)
B16 tranny has shorter gears. RPM in 5th gear would be higher than what it is with your LS tranny. If youre going for a FI setup an LS transmission would be better, IMO. but if you want to go NA a B16 tranny would probably be better.
Old Dec 29, 2005 | 09:25 AM
lVlemphizStylez's Avatar
if you have an ls tranny you shouldnt cruise at 4000 rpm in 5th at 80....i have a b16 and i cruise a little over 4 grand...and no the ls tranny is not better for boost...im not going to go into that again
longer gears are never something better...ignore tre's post (if you need traction that badly, there are other methods than going to a longer geared transmission)
Old Dec 29, 2005 | 09:27 AM
BrooX's Avatar
Look into getting a Quaife LSD aftermarket tranny mated to your LS Tranny. That wouldnt be too bad. Just my opinion.
Old Dec 29, 2005 | 09:32 AM
a2dadamm's Avatar
thanx for the adviceill prob stick with the ls but i still dont know what i wanna do in terms of motor swap or just build the ls ................thanx again tho this is also my first integra so im tryin to get all the info on it b4 i make my choice.
Old Dec 29, 2005 | 09:34 AM
you can build the ls with the money youd use to swap it....and more than likely itd be faster than that swap
Old Dec 29, 2005 | 10:04 AM
CBURKE's Avatar
Not to steel, but I was thinking of doing the same thing. I know it works really well on older Civics with Ls swaps, but what axles would you use on a DC integra with a B16A tranny? Are the hubs the same as a Civic?
Old Dec 29, 2005 | 10:07 AM
Default Re: (CBURKE)
you need a hydro b16...for a hydro ls....aka the SI tranny outta the 99 SI...your axles remain the same...
Old Dec 29, 2005 | 12:46 PM
SilverDc2's Avatar
Default Re: (lVlemphizStylez)
at 80MPH b16 tranny is at 4400-4500 rpm
Old Dec 29, 2005 | 12:47 PM
Default Re: (SilverDc2)
not mine...im around 4200-4300...have to remember wheel diamater can throw it off a couple hundred rpm
best way i tell an si tranny is by 2nd gear...if it goes to 58-60 (on an ls) its not an si tranny...my 2nd gear is over at 51-53
Old Dec 29, 2005 | 12:53 PM
SilverDc2's Avatar
im rolling on stock 195-95-15 ITR bridgstone re010
1st gear 25-27
2nd 50-52
3rd 75-77
4th 102-105
5th ?
Old Dec 29, 2005 | 01:01 PM
dunno your 4th gear seems kinda longer ....mine ends at 100mph...and this is on a 205 40 17....and my third ends at about 73...minor discrepencies though...not everything is created the exact same
Old Dec 29, 2005 | 01:17 PM
RE- v8killa121's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a2dadamm &raquo;</TD></TR><TR><TD CLASS="quote">i herd the b16 tranny is better on the ls motor than the ls tranny what exzactley does it help with..... i do alot of highway travel and when i crusin at like 80 im at 4 grand will a b16 tranny reduce that and make it better on top end ???????? thanx</TD></TR></TABLE>
i got a b16 on a LS tranny and it tops out at about 130-135 mph IN 4th gear..(no power in 5th)
ain't no way it 4 grand at only 80mph...
Old Dec 29, 2005 | 01:19 PM
Default Re: b16 tranny on ls motor (RE- v8killa121)
you do not have a b16 tranny if you can go far over 100mph in 4th gear...sorry...
which is what is being discussed...the b16 tranny...NOT the engine which i think is what youre talking about
Old Dec 29, 2005 | 01:20 PM
Default Re: b16 tranny on ls motor (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">you do not have a b16 tranny if you can go far over 100mph in 4th gear...sorry...</TD></TR></TABLE>
dude, read!
b16 on a LS TRANNY
Old Dec 29, 2005 | 01:21 PM
ya i edited my post..read it...were not talking about the b16 engine at all
Old Dec 29, 2005 | 01:23 PM
loudassVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">at 80MPH b16 tranny is at 4400-4500 rpm</TD></TR></TABLE>
I have a YS1 cable b16 trans, and at 80mph in 5th, I'm cruising @4800.
95mph, I'm at 5600rpm.
End of 2nd, I'm @60mph @8400rpm
End of 3rd, I'm @ 87mph@8400rpm
running the 205/40/17's
Old Dec 29, 2005 | 01:24 PM
Default Re: (loudassVTEC)
the cable trans is geared slightly different than the hydro...i believe if were talking about the same cable tranny
http://www.allmotorhonda.com/t...s.htm
sirhavok
10
Apr 23, 2007 08:55 AM
jarvis199
May 7, 2005 07:51 AM
mrchris386
Nov 24, 2003 07:25 PM
hatchattak
Aug 26, 2003 07:44 AM
lazy bum shaughn
21
Feb 19, 2003 05:50 PM
