NEED HELP CAR WONT START INGNITION PROBLEMS!!!!!!!!!!!!!
Ok i have a 1992 Civic si hatch w/ b18b1 with turbo and I was installing my turbo timer today and i was seeing if my turbo timer was working and i touch the ignition white wire with the bolt that is a part of the ignition. It sparked my finger and then it smoked. After that i put everything back and went inside and later wanted to go somewhere and the ignition dosent have power. I can turn on my lights but the ignition wont get any power, i had checked all the fuses and my ignition wires to see if i had burned anything. I know im an idiot that i would try to touch the ignition to see if it works. If anybody can provide with any info it will greatly be appretiated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic »</TD></TR><TR><TD CLASS="quote">check the main fuses in your engine compartment by the battery.</TD></TR></TABLE>
i second this
i second this
Morag
May 21, 2017 10:12 AM
IdotheSHOCKER
Jun 16, 2002 05:32 PM
