Converting to 5 lug on my EM1, have a couple questions!
Old 12-28-2005, 09:27 AM
1337 Si's Avatar
Default Converting to 5 lug on my EM1, have a couple questions!
I need some help from people who have converted to this on their EM1 or 96+ chassis. We will just say that I have friends that work at Acura and I can get parts for extremely cheap brand new. I have already purchased the caliper sets (front and rear) and plan on getting the knuckles hub and bearing very soon here. Now my question is this:
I have noticed that on all the pics of the 5 lug swap that you get the rear trailing arm, compensator arm, and camber adjustment piece. In order to save some costs, can I just get the rear hub and bearing and install that in my EM1's trailing arms? I mean, they look identical, and I anticipated on using my SRR LCA's and rear camber kit anyway. The only thing I would be concerned with is the mounting locations for the rear calipers and what not. Any insight would be greatly appreciated. Thanks.
Old 12-28-2005, 09:29 AM
R-Lug's Avatar
Default Re: Converting to 5 lug on my EM1, have a couple questions! (1337 Si)
you could, but you'll have to press out the hub and assembly which would be too much work, so that's why ppl just get the whole trailing arm. that's how it usually comes anyways. hard to find it in pieces
Old 12-28-2005, 09:39 AM
1337 Si's Avatar
Default Re: Converting to 5 lug on my EM1, have a couple questions! (SeaLevel)
I have friends that work at machine shops though so that is taken care of
Old 12-28-2005, 09:45 AM
madm@nkey's Avatar
You have to buy the whole trailing arm.
The stub axle the rear hub mounts to is a bit longer than the 4 lug version.
The hub will not seat properly and the calipers will not align with the rotors.
I learned this the hard way.
Use the LCAs and camber links you already have, same for the parking brake cables.
Old 12-28-2005, 09:56 AM
1337 Si's Avatar
Default Re: Converting to 5 lug on my EM1, have a couple questions! (madm@nkey)
Did you have to get the new compensator arm as well?
Old 12-28-2005, 09:59 AM
madm@nkey's Avatar
No, just used the stock EM1 piece until I bought an adjustable link.
Old 12-28-2005, 10:05 AM
1337 Si's Avatar
Adjustable link eh? Got pics or link?
Old 12-28-2005, 10:19 AM
madm@nkey's Avatar
Take a look here:
http://www.technicasport.co.jp/eng/kit.htm
If these are too expensive, try here:
http://www.spcperformance.com/....html
Old 12-28-2005, 02:28 PM
1337 Si's Avatar
ttt
Nextelbuddy
52
11-06-2005 10:56 PM
-auSTIn-
11-14-2004 07:35 PM
bgod
09-26-2004 04:32 PM
hammerdgolfer
07-20-2004 05:53 PM
daddymax
09-20-2003 08:39 AM
Quick Reply: Converting to 5 lug on my EM1, have a couple questions!
