If i go with a differnet turbo do i have to change my flange becasue its a hf manifold?
Old Dec 25, 2005 | 11:53 AM
seeeya04's Avatar
Default If i go with a differnet turbo do i have to change my flange becasue its a hf manifold?
if i go with a differnet turbo do i have to change my flange becasue its a hf manifold?
Old Dec 25, 2005 | 02:19 PM
Adriano's Avatar
Default Re: If i go with a differnet turbo do i have to change my flange becasue its a hf manifold? (seeeya0
It depends on what turbo you have now and what turbo you want to get. Give us more info so we can better help you.
Adriano
Old Dec 25, 2005 | 02:54 PM
seeeya04's Avatar
Right now i have a t3 turbo on it and i will be getting a t3 t4 turbo
Old Dec 25, 2005 | 03:33 PM
beepy's Avatar
No, the T3/T4 uses the same inlet flange as the T3 (same turbine) But the new turbo might not fit. The compressor is of course larger, so if you are tight now it won't fit after.
eastbay92cx's Avatar
Probably wouldn't be a bad idea to look around for a used cast / log manifold too while your at it. I haven't seen any comparisons done, but the hf mani has got to be restrictive especially with a bigger turbo.
sladed16y8
Mar 13, 2007 09:02 AM
sohctodohc
Sep 1, 2006 11:07 AM
Boostin95Teg
Sep 19, 2003 01:07 PM
b18cls1
Sep 18, 2003 03:19 PM
