OIL PRESSURE HELP
Old Dec 25, 2005 | 08:39 AM
ooredteg's Avatar
Default OIL PRESSURE HELP
I drive a 2000 gsr. I just bought a oil pressure guage by autometer. The directions say i have to tap into my oil pan and weld a fitting in. Is there another way so that i dont have to drill into my pan please help. Thanks
Old Dec 26, 2005 | 05:49 AM
cjohnson_2's Avatar
Default Re: OIL PRESSURE HELP (ooredteg)
I have mine hooked up to the stock oil pressure sensor via a Tee.
Old Dec 26, 2005 | 06:47 AM
Racermech's Avatar
Default Re: OIL PRESSURE HELP (cjohnson_2)
Mine is off the back of the block with a brained staninless line going to the gauge. I will try to take a pic of it today (depending on the weather) Dont use the nylon line!!! They break and kink.
Old Dec 27, 2005 | 01:28 PM
ooredteg's Avatar
Default Re: OIL PRESSURE HELP (Racermech)
where is the stock oil pressure sensor to hook that tee up? Thanks for the help so far.
Old Dec 27, 2005 | 01:33 PM
95integraLS003's Avatar
Order a relocation kit for 30 bucks from fast-turbo.com. the guys name is Stan he should hook you up really well! I got it and its some good stuff!!!
No need to tap in to oil pan when you can put it where the stock sensor goes...
Old Dec 27, 2005 | 08:56 PM
b18c198's Avatar
Default Re: OIL PRESSURE HELP (95integraLS003)
Hey guys any of you had problems with your autometer guage not reading properly? Mine won't go over 50psi, so I think the sender unit is bad. Mine is attached into the back of my block as well.
guess I am just going to repalce the whole unit since it's under warranty.
Old Dec 28, 2005 | 02:11 PM
ooredteg's Avatar
Default Re: OIL PRESSURE HELP (b18c198)
Did you try checking all your lines, maybe something is blocking the hose inside. Thas my best guess.
velisma
Jan 30, 2010 08:24 PM
totsie7944
Mar 26, 2008 04:26 PM
k20dc2
Aug 15, 2005 09:24 AM
Turbo_y8
Apr 21, 2005 04:23 PM
civicmandx94
Feb 10, 2003 10:48 AM
