failing TPS
Old Dec 24, 2005 | 05:41 PM
OwnsAnAcura's Avatar
Default failing TPS
odd situation... replaced my clutch, took about 9 hours, start my car up, and its throwing 2 codes.. one was coolant level or something so fixed that easily, and the other was the TPS Sensor... so i checked the voltage of it, .48v at idle and when i floor it it went down to .45v, a guy at autolab said that was almost perfect... so he suggested to get a map of where the 3 wires on the TPS sensor plug into the ecu, and i shud check all them...
does any1 know where the 3 wires from the TPS sensor run through the engine bay and into the ecu?
Old Dec 24, 2005 | 06:05 PM
Default Re: failing TPS (OwnsAnAcura)
anyone???
chevy383
Jan 1, 2014 02:39 PM
8600RPM
Nov 11, 2011 03:23 PM
cranker
Jul 15, 2010 03:22 PM
Tex Blackwell
Apr 13, 2005 04:03 PM
rschoener
May 3, 2002 03:02 AM
