MAP sensor Idle Problems
Old 05-02-2002, 08:42 PM
rschoener's Avatar
Default MAP sensor Idle Problems
I have just Swapped A D16Z6 engine and P28 ECU into my 1989 Civic DX. I have rewired the whole thing. The Car will start and run but will not idle. If i disconnect the MAP sensor the car Runs great and idles at 1200 rpm. The engine light comes on and stays on. Any sugestions I have beeped out all the wires from the ECU to each sensor several times everyting is good.. Any ideas? I also have a lightened Flywheel Stock cut to about 12 pounds
Old 05-03-2002, 03:02 AM
SpeedRacerEX-R's Avatar
Default Re: MAP sensor Idle Problems (rschoener)
Are your map sensor wires going to the correct ecm inputs?
Running925
11-14-2006 07:57 AM
TL1000R
Honda S2000
03-17-2006 11:16 AM
LilCivic04
08-01-2005 11:09 PM
Tex Blackwell
04-13-2005 04:03 PM
Ryanwb
03-31-2003 03:41 PM
Quick Reply: MAP sensor Idle Problems
