b20 swap, got questions
Old Dec 23, 2005 | 08:43 PM
1999blownlsturbo's Avatar
Default b20 swap, got questions
So I got this B20B motor today from attarco, an engine importer, and of course there is no vin number on the block. So I can't figure out what year the motor came out of. The receipt says it's a 1997. The guy there said that I would have to change out my crank sensor. I don't know why he would say that. Isn't 1997 crv obd2? All I should have to change out is my distributor and intake manifold, right?
Old Dec 23, 2005 | 09:21 PM
b20integrapower's Avatar
Default Re: b20 swap, got questions (1999blownlsturbo)
the crank sensor issue he is talking about is the fact that the b20b doesnt have the sensor at all...the ls motor does...its right next to the crank pully...and the year can be located in a little circle right beneath the valve cover in the middle front...get a jumper harness and obd1 ls ecu and u wont have to worry about the crank sensor
Old Dec 23, 2005 | 09:28 PM
pdotjones's Avatar
Default Re: b20 swap, got questions (b20integrapower)
Old Dec 23, 2005 | 10:31 PM
Finger Lickin' good's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">the crank sensor issue he is talking about is the fact that the b20b doesnt have the sensor at all...the ls motor does...its right next to the crank pully...and the year can be located in a little circle right beneath the valve cover in the middle front...get a jumper harness and obd1 ls ecu and u wont have to worry about the crank sensor </TD></TR></TABLE>
keep this 05 member
Old Dec 24, 2005 | 09:39 AM
Default Re: b20 swap, got questions (Finger Lickin' good)
keep it 05? confused
Old Dec 24, 2005 | 10:31 AM
R6E6I6D's Avatar
are u dropping the motor into a obd1, obd2, or obd0 car...?
cause when i did my b20 swap into my car i jsut kept the obd0 dizzy and injectors and junk'd the others... o and u want to keep ur fuel rail. Also myh old LS had the ECT sensor located on the back of the block b20 is located near thermostat on the housing easy just cut some wires in the harnes and solder em back up ...
Old Dec 24, 2005 | 11:39 AM
XYU's Avatar
XYU
Ask me about vaginal warts
I have my B20 in 95 Integra and I just replace the engine. Used original (B18's) injectors and air manifold instead B20's. Thats pretty much it!
Engoy your B20!
Old Dec 25, 2005 | 02:03 PM
Default Re: b20 swap, got questions (DC4 B20)
I have a 99 integra and it is obd2. The motor I got is out of a 97 crv.
Old Dec 25, 2005 | 02:14 PM
Lauj87's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999blownlsturbo &raquo;</TD></TR><TR><TD CLASS="quote">I have a 99 integra and it is obd2. The motor I got is out of a 97 crv. </TD></TR></TABLE>
isn't 99 obd2b? good luck trying to smog that motor because your not going to be able to get it reffed......has to be a 99 motor up so you can make it legale. but if you got the time to swap out once smog time comes around then good job!!!
Old Jan 26, 2007 | 06:29 PM
91 integra's Avatar
Default Re: b20 swap, got questions (R6E6I6D)
I was woundering what do I need to do to swap b20 into a obd0 integra
Old Jan 26, 2007 | 08:44 PM
featherwieght's Avatar
im all ears
but i am just switching out the bottom end
and using a obd0 b16 head
Old Jan 27, 2007 | 11:18 AM
91 integra's Avatar
What's up homie looks lioke you know what you talkin bout so can you help out a little
Old Feb 16, 2009 | 03:02 PM
b18c1ej8's Avatar
If your cars ECU is USDM 96' and newer and the motor is JDM the ECU will look for a CKP which is a crank fluctuation sensor. You can either put a USDM 96 and up oil pump which has the CKP plug or you can make the ECU think that the CKP is running off the CPP which is the Crank Position Sensor. Also you will want to transfer everything from the motor that was in the car to your B20. And if your B20 is the one with the tall Giraffe manifold then obviously that will have to be changed. Any B series mounts will work obviously, if it helps just imagine swapping in an Ls.
Old Feb 16, 2009 | 03:55 PM
spiderrey's Avatar
just completed a b 20 swap into a 90 teg yesterday. simple swap, used the tegs dizzy, intake ex manifold, basically took everything off the b18 and put it on the b 20. car fired right up, the only minor issue was the idle was a couple hundred rpm higher then before. havent addressed that yet. there was only one sensor that didnt swap right into the b 20 block. luckily there was a spot om the b20 that was only about 5 inches from the sensors original location. i drilled it out a tapped it. no big deal. the car looks totally stock when you peak under the hood.this the the hole that had to be tapped
switch installed
i was really inpressed with the cnew clutch set and engine mounts.
Old Aug 10, 2010 | 09:49 PM
gonzy tunning's Avatar
i'm having the same problem with a friend 99 LS INTEGRA hi's engine whent bad
so he end up buying a 97 JDM B20B...SO NOW HIS HAVING check engine light on...with isue we can not pass inspection...what do i have to do plz let me know
Old Dec 18, 2010 | 06:31 PM
CivicSI_HB_B20's Avatar
hey i got a ported, built gsr head with a stock b20z block and i need bigger injector then stock gsr i heard that the b20 prelude injectors will work has anyone heard of this and does anyone know the size of the third gen prelude injectors.
Also im planning to do stroker kit with 9.6 comp will the stock prelude injector still work or will i need to do 370cc injectors
Old Dec 18, 2010 | 06:40 PM
chefboyarluis's Avatar
switch installed
no trans? nice lol
Old Dec 19, 2010 | 12:59 AM
chris18812's Avatar
its a good news
Old Jul 10, 2011 | 10:34 PM
96tegb20turbo!'s Avatar
i got 96 integra with a b20b swap. as b18c1ej8 said the ckp can be read off the cpp and i was wondering how to do that. i have been looking for it but nothing says how to do it. i need to go back to obd2 for ref!
Old Jul 11, 2011 | 09:12 AM
Hidenplanvew's Avatar
you know this thread is from 2005 right????
Old Jul 12, 2011 | 07:53 PM
yeah i saw that. im just hopin someone can help. lol.
Thategguy94
Feb 7, 2015 01:15 PM
uindaway
Mar 7, 2013 04:56 PM
Thorshammer
Jun 12, 2012 09:39 AM
nels00n
19
Aug 16, 2010 08:04 AM
B16Civic93
Jun 21, 2006 09:21 PM
