whats the diff between a 92 integra motor and a 95 integra motor?
Old Dec 23, 2005 | 02:31 PM
the.hamburglar's Avatar
Default whats the diff between a 92 integra motor and a 95 integra motor?
b18a vs. b18b. both obd1. are they pretty much the same?
Old Dec 23, 2005 | 02:35 PM
projectTeG's Avatar
basically the same. the b18b intake manifold and cams are a bit different(better) than both gen b18a1.
90-91 b18a1:130hp 121tq
92-93 b18a:140 hp 126tq
Modified by projectTeG at 11:57 PM 12/23/2005
Old Dec 23, 2005 | 02:37 PM
Default Re: (projectTeG)
better on the b18b? so the bottom end is the same if i were to do an ls vtec?
Old Dec 23, 2005 | 02:38 PM
Default Re: (the.hamburglar)
also how can i tell by looking at the motor that its obd1 when i head to the junk yard to find one?
Old Dec 23, 2005 | 03:01 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">also how can i tell by looking at the motor that its obd1 when i head to the junk yard to find one?</TD></TR></TABLE>
you can look at the engine date code on the head it will say 9/1-9/4 for it to be obd1. other than that if you know how to tell the difference between the plugs on the engine you can tell.
Old Dec 23, 2005 | 03:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">
you can look at the engine date code on the head it will say 9/1-9/4 for it to be obd1. other than that if you know how to tell the difference between the plugs on the engine you can tell.</TD></TR></TABLE>
thanks, cant you also tell by looking at the dizzy? where abouts is this code on the head?
Old Dec 23, 2005 | 03:25 PM
92DAIntegraXSI's Avatar
im interested in this cam difference i have b18b cams sitting in my box at work
Old Dec 23, 2005 | 03:36 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">thanks, cant you also tell by looking at the dizzy? where abouts is this code on the head?</TD></TR></TABLE>
yes the dizzy has different plugs. the head year is right about the 4 and 3 exhaust ports.
it will kinda look like this (9/1)
a take the year of the car subtract on year and youll get the year of the head.
so for it to be obd1 its will say (9/1)- (9/4)
it will look like that
Old Dec 23, 2005 | 03:41 PM
ok, but if the motor is just sitting there i will not know the year of the car it was pulled out of. does anyone have a pic? arnt there like certrain wires on the obd1 dizzy that are unique? so i can look for them?
Old Dec 23, 2005 | 03:44 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">ok, but if the motor is just sitting there i will not know the year of the car it was pulled out of. does anyone have a pic? arnt there like certrain wires on the obd1 dizzy that are unique? so i can look for them?</TD></TR></TABLE>
well by looking at the head code you can most of the time tell the years of the car it came from. a 93 car will have a 92 stamp on the head.
"Distributor is OBD1 for sure.
OBD0 (pre OBD) distributors have two translucide round plugs
OBD1 distributors have two grey rectangular plugs,
OBD2 (at least OBD2a) distributors have 1 square grey plug.
Also, I THINK (not sure here) that electronic VSS on the tranny would indicate that it's Hydro... therefore OBD1 is logical. However the looking at the distributor is more reliable.
Olivier"
https://honda-tech.com/zerothread?id=720864 got it from that thread
Old Dec 23, 2005 | 04:37 PM
it will look like that</TD></TR></TABLE>
so then what year is your motor? it looks like 9/1 - 9/0?
Old Dec 23, 2005 | 04:51 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">so then what year is your motor? it looks like 9/1 - 9/0?</TD></TR></TABLE>
its a 91 engine, so it would go into a 92 car.
Old Dec 23, 2005 | 07:04 PM
so you have an obd1?
Old Dec 23, 2005 | 07:28 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">so you have an obd1?</TD></TR></TABLE>
oh ****...lol, i thought you were asking the year of the pic
my engine is a 93 ls engine and its has (9/2) on the head. and yes its obd1. obd1 was from 92-95. so if your looking for it on the engines it be (9/1) -(9/4)
Old Dec 23, 2005 | 08:50 PM
1999blownlsturbo's Avatar
How can you tell if it is all in Japanese?
Old Dec 23, 2005 | 09:00 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (1999blownlsturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999blownlsturbo &raquo;</TD></TR><TR><TD CLASS="quote">How can you tell if it is all in Japanese? </TD></TR></TABLE>
http://www.team-integra.net/se...D=513
that should help some what.
Old Dec 23, 2005 | 09:04 PM
Default Re: (00IntegrAllmotoR)
There is no vin on the block. The only numbers that are on the block are B20B 1135416 and P75. Any ideas?
Old Dec 23, 2005 | 09:14 PM
92integraVTECgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">basically the same. the b18b intake manifold and cams are a bit different(better) than both gen b18a1.
Modified by projectTeG at 11:57 PM 12/23/2005</TD></TR></TABLE>
are those numbers right?? so would the B18a (92-93) block be better for LS/VTEC??
Old Dec 23, 2005 | 09:45 PM
Default Re: (92integraVTECgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integraVTECgsr &raquo;</TD></TR><TR><TD CLASS="quote">
are those numbers right?? so would the B18a (92-93) block be better for LS/VTEC??</TD></TR></TABLE>
so the 92-93 b18a has 140hp which is the same as the b18b 94-95? so it doesnt really matter what motor to look for?
Old Dec 23, 2005 | 09:47 PM
my engine is a 93 ls engine and its has (9/2) on the head. and yes its obd1. obd1 was from 92-95. so if your looking for it on the engines it be (9/1) -(9/4) </TD></TR></TABLE>
i dont see the "9/2" in the pic you posted. that is not your motor then?
Old Dec 23, 2005 | 10:08 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">i dont see the "9/2" in the pic you posted. that is not your motor then?</TD></TR></TABLE>
no, thats a pic i used as a reference.
nicks-eg6
Jan 31, 2008 01:17 PM
tractionless
Apr 25, 2006 08:02 PM
PhatBoy5015
Jan 19, 2006 01:15 AM
the.hamburglar
Dec 30, 2005 08:10 PM
