Differences between B18A and B18B?
Old Jan 14, 2006 | 06:59 PM
PhatBoy5015's Avatar
Default Differences between B18A and B18B?
I'm sure this has been covered a million times, but I searched and could not find what I needed. So what are the differences between these two motors? Or please list some links to help me. Thanks.
Old Jan 14, 2006 | 09:45 PM
projectTeG's Avatar
Default Re: Differences between B18A and B18B? (skylinedo)
engine wise..its the mainly the cams and intake manifold.
remeber that the b18a1's came in 2 different ratings
Old Jan 15, 2006 | 08:43 PM
Default Re: Differences between B18A and B18B? (projectTeG)
I have a motor from a 92 Integra. Is this OBDI or OBD0? I am going to install a B18B head on the 92 block. Is there anything on the block that needs to be changed to OBDI, if it is OBD0?
Old Jan 15, 2006 | 09:42 PM
non-vtecpower's Avatar
94 and up B18b1 142 hp 127tq
90-91 B18a1 130 hp 121 tq (obd0)
92-93 B18a1 140 hp 121 tq
The 94-95 B18b1 (obd1) is the best LS motor
Modified by non-vtecpower at 4:15 AM 1/17/2006
Old Jan 16, 2006 | 08:49 AM
projectTeG's Avatar
Default Re: (non-vtecpower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-vtecpower &raquo;</TD></TR><TR><TD CLASS="quote">94 and up B18b1 142 hp 127tq
92-93 B18a1 140 hp 121 tq (obd0)
The 94-95 B18b1 (obd1) is the best LS motor</TD></TR></TABLE>
wrong....ill correct this yet again
92-95 is obd1...first off
the 92-93 b18a1 had 140 hp and 127tq
Old Jan 16, 2006 | 09:03 AM
ernald711's Avatar
Default Re: (projectTeG)
have a 98 and i must agree.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">
the 92-93 b18a1 had 140 hp and 127tq</TD></TR></TABLE>
hahahahaaa n00b.
Old Jan 16, 2006 | 09:06 AM
projectTeG's Avatar
Default Re: (ernald711)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 &raquo;</TD></TR><TR><TD CLASS="quote">have a 98 and i must agree.
hahahahaaa n00b.</TD></TR></TABLE>
me or?
i also agree on the 94-95 statement....but ist not really the engine that is better, it the obd. obd1 is always going to be more forgiving then obd2.
Old Jan 16, 2006 | 09:20 AM
Azn Kenny's Avatar
So if one were to convert to obd1 would that be the same as a motor that came with obd1?
Old Jan 16, 2006 | 12:43 PM
T3T495GSR's Avatar
Default Re: (LSntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSntegra &raquo;</TD></TR><TR><TD CLASS="quote">So if one were to convert to obd1 would that be the same as a motor that came with obd1?</TD></TR></TABLE>
yes
Old Jan 16, 2006 | 05:42 PM
Default Re: (T3T495GSR)
So a 92 B18a1 is OBD1?
Old Jan 16, 2006 | 05:51 PM
projectTeG's Avatar
Default Re: (PhatBoy5015)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 &raquo;</TD></TR><TR><TD CLASS="quote">So a 92 B18a1 is OBD1? </TD></TR></TABLE>
yes 92-95 is obd1
Old Jan 16, 2006 | 05:59 PM
scheistermeister's Avatar
whats involved in converting from obd0 to obd1? ive only seen links from obd2 - obd1
Old Jan 17, 2006 | 03:37 PM
GSRVTEC1's Avatar
ayy man i dunno but i felt so many obd2 ls compare to obd1 94 ls. the 94 ls seems to pull alot harder then the 98+
Old Jan 17, 2006 | 07:32 PM
Default Re: (GSRVTEC1)
So I have a 92 B18a1. When I swap the head to a B18B, I can reuse my distributor right from the 92? After the head swap it will basically be identical to a B18B Obd1? Just wanna make sure I can reuse the B18a dizzy.
Old Jan 17, 2006 | 07:41 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 &raquo;</TD></TR><TR><TD CLASS="quote">So I have a 92 B18a1. When I swap the head to a B18B, I can reuse my distributor right from the 92? After the head swap it will basically be identical to a B18B Obd1? Just wanna make sure I can reuse the B18a dizzy.</TD></TR></TABLE>
yes the heads are the same
Old Jan 18, 2006 | 10:52 AM
stockcolt's Avatar
Default Re: Differences between B18A and B18B? (PhatBoy5015)
92 would be obd1
Old Jan 18, 2006 | 02:51 PM
2.vent0's Avatar
Default Re: Differences between B18A and B18B? (stockcolt)
Well this is very helpful, as im looking at a b18 for my soon to be new car. how hard would it be to drop it into a da?
Old Jan 18, 2006 | 03:36 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: Differences between B18A and B18B? (2.vent0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.vent0 &raquo;</TD></TR><TR><TD CLASS="quote">Well this is very helpful, as im looking at a b18 for my soon to be new car. how hard would it be to drop it into a da?</TD></TR></TABLE>
um probably as hard as replacing the engine with the same thing
Old Jan 18, 2006 | 05:03 PM
i_see_red's Avatar
Default Re: Differences between B18A and B18B? (benb18a)
probably a dumb question but would a 94 LS motor fit directly without any mods into a 92 LS body? i might need to swap mine out due to high milage soon so if it fits directly than i rather get a 94 instead of a 92.
Old Jan 18, 2006 | 05:19 PM
Default Re: Differences between B18A and B18B? (i_see_red)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i_see_red &raquo;</TD></TR><TR><TD CLASS="quote">probably a dumb question but would a 94 LS motor fit directly without any mods into a 92 LS body? i might need to swap mine out due to high milage soon so if it fits directly than i rather get a 94 instead of a 92. </TD></TR></TABLE>
a friend of mine has a 94 b18b in his 91; ill ask him to be sure but i think its the same. its basically the same exact engine.
Old Jan 19, 2006 | 01:15 AM
projectTeG's Avatar
yes
GYChris
Jan 29, 2008 07:57 PM
tractionless
Apr 25, 2006 08:02 PM
D1andOnly
Nov 26, 2005 07:21 AM
the.hamburglar
May 27, 2005 05:24 AM
gildo86
May 31, 2004 11:41 AM
