Higher idle speed after clutch and flywheel install.
Old Dec 21, 2005 | 02:05 PM
SWC's Avatar
SWC
Default Higher idle speed after clutch and flywheel install.
I just installed XTD stage4 clutch and 8lbs flywheel. Now the idle speed is 1100 which is 300 higher than before. Also sometimes the idle is going up and down little bit. Is this because of the lighter flywheel? or improper installation?
Any opinion? Thanks.
Old Dec 21, 2005 | 02:33 PM
nsxmatt's Avatar
Default Re: Higher idle speed after clutch and flywheel install. (SWC)
It's because of something else, not the clutch. Maybe you have a loose vac line or something like that. Double check everything.
Old Dec 21, 2005 | 04:16 PM
SWC's Avatar
SWC
Default Re: Higher idle speed after clutch and flywheel install. (nsxmatt)
I checked everything again and found no problem. The wierd thing is that the idle is not steady. Sometimes when I push clutch pedal at dead stop, it came back to normal 800 and steady. After driving again, then the idle is going up and down again or steady higher. I'm guessing the ecu to try find out the idle point with the new lighter flywheel. But not sure. Anyone else?
Old Dec 21, 2005 | 06:58 PM
h kid's Avatar
im having the same prob with my new clutch and fly wheel set up but I dont really care. just thought id tell you that the same thing hapened to me.
Old Dec 21, 2005 | 10:39 PM
SWC's Avatar
SWC
Default Re: Higher idle speed after clutch and flywheel install. (h kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h kid &raquo;</TD></TR><TR><TD CLASS="quote">im having the same prob with my new clutch and fly wheel set up but I dont really care. just thought id tell you that the same thing hapened to me.</TD></TR></TABLE>
How long have you had this problem? And what clutch and flywheel are you running?
Old Dec 21, 2005 | 10:42 PM
wantboost's Avatar
Who is Mr Robot?
the ecu is trying to relearn the idle..... unplug the ecu for awhile and plug it back in... it should relearn the idle characteristics of the motor...... when you had the other flywheel in it weighted more so it took more of the IACV to get it to idle, now the ecu wont go below that setting its memorized.
Old Dec 22, 2005 | 02:36 PM
SWC's Avatar
SWC
Default Re: Higher idle speed after clutch and flywheel install. (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">the ecu is trying to relearn the idle..... unplug the ecu for awhile and plug it back in... it should relearn the idle characteristics of the motor...... when you had the other flywheel in it weighted more so it took more of the IACV to get it to idle, now the ecu wont go below that setting its memorized.</TD></TR></TABLE>
It seems to be fine after I adjusted idle switch(?) on the throttle body little bit lower. Is it proper way to fix this problem?
Old Dec 22, 2005 | 03:31 PM
jfoster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SWC &raquo;</TD></TR><TR><TD CLASS="quote">
It seems to be fine after I adjusted idle switch(?) on the throttle body little bit lower. Is it proper way to fix this problem?</TD></TR></TABLE>
After I installed my clutch/turbo set up/chipped ecu/uberdata/etc I had a somewhat erratic idle , mainly just too low.
I was able to get it slightly better with the TB adjustment screw. Shortly afterward it gave me a CEL, I just needed to reset the ECU after the adjustment.
Thought I would share incase your adjustment gets you a CEL.
Old Dec 22, 2005 | 06:02 PM
h kid's Avatar
How long have you had this problem? And what clutch and flywheel are you running?</TD></TR></TABLE>
got the clutch and fly wheel in about 3 days ago
Old Dec 22, 2005 | 06:06 PM
SWC's Avatar
SWC
Default Re: Higher idle speed after clutch and flywheel install. (jfoster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfoster &raquo;</TD></TR><TR><TD CLASS="quote">
Thought I would share incase your adjustment gets you a CEL.</TD></TR></TABLE>
No CEL's so far. I'll reset the ecu if I got the CEL.
Thanks for your info.
got the clutch and fly wheel in about 3 days ago</TD></TR></TABLE>
Try this. It works for me.
Old Dec 22, 2005 | 08:21 PM
sohctodohc's Avatar
dumb *** ? but by resetting the ecu you mean taking the negative cable off the battery???
Old Dec 22, 2005 | 09:23 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Higher idle speed after clutch and flywheel install. (sohctodohc)
yea, but that also kills your radio... just unplug the ecu from the harness and let it sit for about 10 minutes
Old Dec 22, 2005 | 09:45 PM
HiProfile's Avatar
I believe the helms manual says (on obd1 cars) unplug a certain fuse for 10 seconds, and that does the trick. Not 10 minutes - it's not like a sub capacitor.
The way hondas idle is mainly though the idle ajustment screw and the ecu adjusting the IACV. You set the idle to 400 or so with the IACV unplugged, and then it should idle around 700-800 after plugging it back in. Reset the ecu before and after. The reason it wants to idle faster is obvious - that's a lot of rotating mass you just took off the motor. For instance, on a b-series, OEM to 8lbs is the same as 275lbs less in the car for 1st gear.
Anyways, it makes the motor spin faster with the same amount of air (less weight resisting motion). When you think about it, at idle the crank is actually always accellerating and decellerating. Alt/PS/AC/oil&water pump, belts, tranny shaft sloshing fluid around, motor/trans bearings - all sapping power & decellerating the crank in between ignition. When the idle is set above that of which the ecu is set for, it will idle crazy.
wowowee
Jul 27, 2005 05:10 PM
dohcguy
Jun 29, 2005 04:18 PM
Spade
Jan 8, 2003 01:51 AM
rice4life
Mar 5, 2002 03:39 PM
