Installing oil pump on GSR
Old Dec 21, 2005 | 07:17 AM
2.2 teg's Avatar
Default Installing oil pump on GSR
I have searched and came up with nothing specific. What steps are involved in doing this? Also, is there any gasket i need to put the pump or does it just bolt right up? I need help ASAP!!! will most likely do this friday.
or if anyone has found a step-by-step how to, please post the link thanks.
Old Dec 21, 2005 | 09:20 PM
2.2 teg's Avatar
Default Re: Installing oil pump on GSR (importtunerboy)
bump
Old Dec 21, 2005 | 10:56 PM
KooK's Avatar
Mustang Sally
Its kind of a bitch...
Take off all your acc. pulley belts, take off your crankshaft dampener
Take off your timing belt (Good time to replace it, waterpump and tensioner pulley)
After that I believe it should be pretty exposed.
It's harder than it sounds, good luck man
Old Dec 22, 2005 | 04:30 AM
IN VTEC's Avatar
Clean off the old Hondabond HT with lacquer thinner & scotch-brite pad, and hose off the area with brake parts cleaner. Re-apply Hondabond HT in a thin, evenly coated smear around the pump's sealing edge. Don't use too much, a thin smear is enough, otherwise it'll ooze all over the place when you tighten the pump down.
Clean out the oil pan as necessary.
Old Dec 22, 2005 | 05:13 AM
HONDA RR's Avatar
Default Re: Installing oil pump on GSR (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Clean off the old Hondabond HT with lacquer thinner & scotch-brite pad, and hose off the area with brake parts cleaner. Re-apply Hondabond HT in a thin, evenly coated smear around the pump's sealing edge. Don't use too much, a thin smear is enough, otherwise it'll ooze all over the place when you tighten the pump down.
Clean out the oil pan as necessary.</TD></TR></TABLE>
Old Dec 22, 2005 | 09:04 PM
2.2 teg's Avatar
Default Re: Installing oil pump on GSR (HONDA RR)
is there any where with a step by step guide, with pics perhaps?
Old Dec 22, 2005 | 09:55 PM
Sar Face's Avatar
get a manual, it's pretty basic from there
Corksil
Jan 25, 2011 10:36 AM
medic4.life
Jul 16, 2007 08:02 PM
JokerTypeR
10
Jul 21, 2006 12:56 PM
ej1_lsvtec
Feb 4, 2006 06:55 PM
