B20vtec crankcase ventilation.
Old Dec 20, 2005 | 09:57 PM
Toadfart's Avatar
Default B20vtec crankcase ventilation.
I'm building a B20vtec motor and I'm kind of worried about crankcase pressure. I'm planning to tap into one of the plugs on the block Endyne style. From there, to a inline catch can, then to the PCV valve. All enclosed system without venting to the atmosphere.
Would one plug on the back of the block be enough to relieve the pressure of a 11.5:1 compression motor revving to mid 8000 rpms? Or should I add another plug and redo my system?
Old Dec 21, 2005 | 01:59 AM
fmrprojects's Avatar
Default Re: B20vtec crankcase ventilation. (Toadfart)
yeah that would work
Old Dec 21, 2005 | 05:36 PM
Toadfart's Avatar
Default Re: B20vtec crankcase ventilation. (fmrprojects)
Cool. So no need for dual plugs like Endyne's catch can uses?
Old Dec 21, 2005 | 06:50 PM
mx621's Avatar
i drilled out my oil fill cap, and put the pcv valve in the cap on my old ls/vtec setup.
the b20/ls motors have the pcv valves on the valve cover anyway. worked fine for me.
Old Dec 21, 2005 | 08:05 PM
Toadfart's Avatar
Default Re: B20vtec crankcase ventilation. (mx621)
Right on. Thanks.
scottysCRXsi
Apr 2, 2009 08:53 PM
be18see1
Jul 17, 2008 12:53 AM
ek_chris
Jun 10, 2007 08:52 AM
streetlvlhatch
Aug 16, 2004 08:41 AM
sander
Mar 16, 2003 08:23 PM
