Valve to piston clearance
Old Dec 20, 2005 | 04:26 PM
jiahanhao's Avatar
Default Valve to piston clearance
Hi, I was wondering if anyone knew if I would be alright with a ten thousandths milled head, skunk2 stage 2's, and JDM ITR pistons?
baonest's Avatar
Default Re: Valve to piston clearance (jiahanhao)
clay the motor and find out
Old Dec 20, 2005 | 04:27 PM
jiahanhao's Avatar
Default Re: Valve to piston clearance (baonest)
i was hoping to avoid claying
Old Dec 20, 2005 | 04:38 PM
Mythias's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jiahanhao &raquo;</TD></TR><TR><TD CLASS="quote">i was hoping to avoid claying </TD></TR></TABLE>
Never take a shortcut when building a motor.
Old Dec 20, 2005 | 04:43 PM
FAST4DR's Avatar
Telling you to clay is the safe bet.
With that said...we've run FAR more aggressive B18 builds with bigger sticks (Cs and Ds - I still curse them), CTRs, and much more milling - chad would remember, but I think one time we had milled the block so the pistons were out of the hole .010 and the head - we had no choice - was milled at least .025- .030.
I'll PM him for the full details so he can chime in.
Good luck.
Old Dec 20, 2005 | 04:46 PM
92TypeR's Avatar
FSAE
Default Re: Valve to piston clearance (FAST4DR)
If degreed correctly, you will not have any P-2-V contact at TDC.
However, to know the full range of adjustment on the cams, claying is necessary.
Old Dec 20, 2005 | 10:32 PM
b18c-rDC2's Avatar
Default Re: Valve to piston clearance (92TypeR)
you wont have any piston to valve clearance issues at all...I had skunk2 stage 2 cams, ctr pistons, and head milled 30k....
Modified by b18c-rDC2 at 3:54 PM 12/21/2005
Old Dec 21, 2005 | 11:33 AM
Ausmith's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jiahanhao &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I was wondering if anyone knew if I would be alright with a ten thousandths milled head, skunk2 stage 2's, and JDM ITR pistons?</TD></TR></TABLE>
Yes assuming you haven't milled the head before. We've run -20k with a Mugen gasket and JDM ITR pistons with no problems.
monster_c
Nov 26, 2011 12:23 AM
lsvtec2000
Dec 23, 2007 05:50 AM
allmotorsecret
Mar 23, 2006 10:50 PM
TrnsferErr
19
Jan 22, 2006 05:53 PM
LSTEG96
Apr 7, 2004 02:51 PM
