Valve clearance question
Old Apr 6, 2004 | 06:43 PM
LSTEG96's Avatar
Default Valve clearance question
ok heres the setup:
b18b1 block
b18c1 head
pr3 pistons
will skunk2 stage 2 clear? if not, will stage 1??
Old Apr 6, 2004 | 06:53 PM
zilverz's Avatar
Default Re: Valve clearance question (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">ok heres the setup:
b18b1 block
b18c1 head
pr3 pistons
will skunk2 stage 2 clear? if not, will stage 1??</TD></TR></TABLE>
Im not sure of the answer for you... but if you want to be on the safe side.. you can always have a machine shop grind the valve reliefs down on the pistons a little further
Old Apr 6, 2004 | 06:58 PM
LSTEG96's Avatar
Default Re: Valve clearance question (zilverz)
yeah, i was thinkin of that
but the pistons are oem spec, and there wouldnt be much to machine off...
Old Apr 7, 2004 | 02:51 PM
LSTEG96's Avatar
bump? anyone?
lsvtec2000
Dec 23, 2007 05:50 AM
skylerjdm
Jan 5, 2007 08:08 PM
jiahanhao
Dec 21, 2005 11:33 AM
00bluesi
Jun 17, 2003 09:04 PM
