mild steele not easy to weld ???
Hello.
I finished my search here in Germany for a material that is nearly comparable to the mildsteele 1018.
The supplier told me that it is very difficult to weld but couldn´t tell me more about that.
What are your experiencees with that or are there any things that I have to take care of?
What filler for mild-to-stainless321-welding? I thought 347 would be the right stuff?
Thanks
Thanks
Here are the ingerdients of the material that I can get:
0.35-0.45%C (carbon)
0.20-0.4.%Si
1.3-1.6%Mn
0.035%Pphosphorus
0.035%Sulphur
There you can see that it doesn´t contain chrom or molybdenum. Why do you think that this can be a problem?
What do you guys suggest me? If you want to help me please give me the ingredients of the materials because your AISI system doesn´t exist here and so it is nearly impossible for me to compare that to our sytematic.
Thanks
0.20-0.4.%Si
1.3-1.6%Mn
0.035%Pphosphorus
0.035%Sulphur
Thanks
What I not understand is - why use companys like fullrace and lovefab mildsteel if it seems to be such a problem to weld? - Just a question of the price?
In the past,I ever took stainless for my flanges but had a lot of problems with shrinking while welding - so the holes weren´t in the same location than before.
So I decided to try mildsteele or are there other suggestions?
Thanks
Thanks
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kookz »</TD></TR><TR><TD CLASS="quote">The material you were asking about was chromoly or something similar, which is "difficult" to weld. That's not the right material.</TD></TR></TABLE>
When your welding chromoly you use mild steel rod.Unless it is going to be heat treated.Then you use the correct chromoly rod.
crxsir23
Welding / Fabrication
Jul 19, 2007 09:20 AM
