PROS NEEDED!!!! striped block thead
hey there guys need you help again heres my problem!
i built a LS/VTEC motor ran great then he over heated the motor and the head gasket went. So we sent out the head to be decked, so that all fine and dandy.
But we were putting the head bolts back in, and the threads came out with the bolts becasue of the heat now i need a fix.
Can you use ARP head bolts with healiie coils or with it not work becasue of diference of metals. i had a guy that told me it would not work.
When posting please rember that the motor is around 12.2 to 1 compression.
Has any one done this to there blocks and if so did it work, how long for (miles) and what setup are you running.
Thanks again guys your input is needed!!!
shermanyang
Mar 29, 2003 11:02 PM
CRX_VTEC
Jan 9, 2003 11:05 PM
