tranny problem, what could it be?
Old Dec 18, 2005 | 03:42 PM
baonest's Avatar
Default tranny problem, what could it be?
its a 1996 transmission with roughly 107K miles on it. B18B
trans fluid is fresh, changed 2 days ago
cluth has fluid, bled it earlier to make sure there is no air.
shift linkage looks normal.
it has a short shifter.
shifts normal when car is off
when car is on, first few shifts in gears go in (not as easy as normal) but it starts to get harder and ends up me trying to force it in. it will go into gear if i want it to, but its not normal.
could it be a worn out throw out bearing?
when i push the clutch in and release slowly (slow enought to try to feel something), i can feel a little bit of awkardness in the clutch pedal, its not a smooth release like my ITR or civic.
thanks
Old Dec 18, 2005 | 05:00 PM
Aquafina's Avatar
T/O bearing comes to my mind. If you pump the clutch before shifting is it any different?
Old Dec 18, 2005 | 05:03 PM
ITR#132's Avatar
Default Re: tranny problem, what could it be? (baonest)
If it goes in and out of gear smooth with the motor off; its time for a new clutch
Old Dec 18, 2005 | 05:52 PM
baonest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">T/O bearing comes to my mind. If you pump the clutch before shifting is it any different?</TD></TR></TABLE>
no, pumping the clutch doesnt make any difference.
^ makes sense. might as well replace the clutch
Old Dec 18, 2005 | 08:12 PM
Chris F's Avatar
Bleed the clutch fluid first, could be one of those master/slave cylinders.
Old Dec 18, 2005 | 08:14 PM
KayOs's Avatar
Default Re: tranny problem, what could it be? (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Bleed the clutch fluid first, could be one of those master/slave cylinders.</TD></TR></TABLE>
You could still have air in the lines...or one of the above cylinders has gone bad.
rob d's Avatar
the slave is toast.
Old Dec 18, 2005 | 08:34 PM
baonest's Avatar
Default Re: tranny problem, what could it be? (rob d)
ahhh yes. good input guys. i actually have a spare slave cyl. ill throw on and see if it fixes anything. that would be much much better than a clutch swap. but then again, 107K miles could due for a clutch job.
Old Dec 18, 2005 | 09:03 PM
Bbasso's Avatar
Clutch is needed, but like you said go the cheap route first.
Old Dec 19, 2005 | 05:31 AM
Rene M's Avatar
Hyd fluid bypassing.. Dump the master and slave.
Been there on the track car before.
Old Dec 19, 2005 | 10:12 AM
baonest's Avatar
Default Re: tranny problem, what could it be? (Rene M)
ok its not the slave.
gotta change clutch.
Old Dec 19, 2005 | 11:41 AM
totsie7944's Avatar
that sucks man. Good luck with the clutch swap out.
Old Dec 19, 2005 | 02:16 PM
baonest's Avatar
Default Re: tranny problem, what could it be? (totsie7944)
i think the hardest thing is gonna be getting a clutch during this holiday rush.
hmmm
hopefully i can snag one off a motor at work.
lisajasmin
Jun 4, 2008 04:56 PM
ramos2589
13
Jan 29, 2008 07:57 AM
allmotorbl
10
Jun 12, 2006 03:18 PM
o0Jash0o
Jun 9, 2006 04:08 AM
RSVTECDC4
Oct 29, 2004 07:37 AM
