FINALLY!
Old Dec 18, 2005 | 03:22 PM
crxsi8's Avatar
Default FINALLY!
got the ls/vtec to FIRE!..yah! and now two more problems? idle's high and HUB's are locking when tightn'n the axle lock!..any help? stock Si hubs but b series axle? anyone haveing this problem!
Old Dec 18, 2005 | 03:24 PM
R_type's Avatar
Default Re: FINALLY! (crxsi8)
i think that there is a metal ring on the axel or something that makes it lock up when you tighten it.... but i think that you might just be able to take it off... but dont qoute me on that
Old Dec 18, 2005 | 03:29 PM
crxsi8's Avatar
this problem bothers me a lot!??
Old Dec 18, 2005 | 04:38 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (crxsi8)
yeah did you remove the dust ring on the hubs? its a little metal lip that just pops out. that might be causing them to bind.
Old Dec 18, 2005 | 04:53 PM
crxsi8's Avatar
Default Re: (sanimalp)
no i didn't remove it? but can i just remove it, I hope this solves the problem!
Old Dec 18, 2005 | 04:59 PM
sanimalp's Avatar
$cat /dev/urandom
yes. just use a flat head screwdriver it should pop out with minimal drama. you should need to pop the lower ball joint and take off the axle nut and pull the axle out and you should be looking at the ring on the inside of the hub. they made it removable so you could press your ball joints in and out.. and it just so happens that if you remove it b series axles fit just right.
Old Dec 18, 2005 | 05:00 PM
crxsi8's Avatar
okay we didn't do that? i hope this works!...
Randysi
Jul 11, 2012 07:20 PM
ill fast
Dec 5, 2008 06:14 AM
Turbocivic94
Apr 11, 2006 06:53 PM
kefka
Jul 16, 2004 03:34 PM
dkasakitis
Feb 12, 2003 05:04 AM
