my first setup, suggestions?
howdy folks this is my first post in the section.
i have a 90 civic si (stock d16a6) and so far this is what ive aquired for my homemadeturbo.com inspired project.
plan on running 5-8 psi *hopefully*
d16z6 intake manifold
garret m27 turbo
std manifold
dsm bov
fmic
dsm 450cc injectors
b&m command flow AFPR
right now and probably for awhile all i have for fuel/spark management is a MSD boost timing master and a Field SFC.
think i will be able to use this set up for a daily driver until i save up enough to get it tuned/chipped?
also any reccomendation on how many degrees to retard my timing? kinda wanna ask around before i start tuning myself so i dont fry my motor.
all feedback greatly appreciated
garret m27 turbo
std manifold
dsm bov
fmic
dsm 450cc injectors
id reccomend waiting until you could even afford some cheap management (uberdata [ http://uberdata.pgmfi.org/])
other then that it doesnt sound too bad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJxr »</TD></TR><TR><TD CLASS="quote">from what i see on that site it say it only works with obd1 set ups, im obd0.
hmmm, would turboedit do the deed correctly?</TD></TR></TABLE>
i totoally forgot that
Turbo edit is for teh boosted obd0 people
Do some research, you'll find out it isn't as expensive as you probably thought.
mattEG
Aug 24, 2004 11:26 AM
