built d16z6, how hard should it be to turn the short block?
Old Dec 18, 2005 | 01:36 PM
Sinner's Avatar
Default built d16z6, how hard should it be to turn the short block?
I just finished putting a short block together TT rods and vitara pistons. How easy or difficult should the short block spin?
Nick
Old Dec 18, 2005 | 02:07 PM
splitime's Avatar
Default Re: built d16z6, how hard should it be to turn the short block? (Sinner)
Are you referring to the crank? Assuming its together properly, and assembly lubed up... it should spin fairly easily.
Old Dec 18, 2005 | 02:21 PM
SOHCmaster's Avatar
with no sparkplugs in the motor a ratchet wrench should be able to turn it with little effort
Old Dec 18, 2005 | 05:01 PM
CoreyR's Avatar
Default Re: (SOHCmaster)
it should be pretty tight, it should not spin freely if it has all new rings/hone etc.
Old Dec 18, 2005 | 05:09 PM
Importordomestic's Avatar
Default Re: (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">it should be pretty tight, it should not spin freely if it has all new rings/hone etc.</TD></TR></TABLE>
I agree -^^^^^^^
but if it was just the crank by itself it should spin fairly easily.
Old Dec 18, 2005 | 05:51 PM
Sinner's Avatar
yes its crank+ rods + pistons+ new rings and hone.
Old Dec 18, 2005 | 06:56 PM
SOHCmaster's Avatar
Yes of course, I ment it still should turn by using a wrench with no plugs, not like 1 finger turns come on.
Old Dec 18, 2005 | 07:33 PM
nonvtecD's Avatar
When I built my motor, before I put the crank pulley on I could grab the end of the crank and turn it over with my hand. It was hard and it hurt my hand, but still, it was possible.
Old Dec 18, 2005 | 07:49 PM
Joseph Davis's Avatar
Pulley on the crank, you should be able to turn it over with some smooth resistance. Just like when testing out the main bearings, before you bolt down the rods, by twisting the crank it should feel smooth with no catches.
B18CUL8R
Jul 11, 2008 09:39 PM
Swipe'd
Mar 3, 2007 06:17 AM
Phaze2 Mike
Feb 5, 2004 06:16 AM
