Swap
Ok guys I know this information is some where on this forum but I really don't have time to find it. I just bought a ls/vtec swap for my eg hatch. The swap came out of a eg hatch and he gave me the complete wiring harness. My qustion is I have a d16z6 with a p28 ecu which i also now have a p72 to. Could I just use my harness instead of his ? Btw way what tranny is this the vin # is s803049730. Thanks
So you have a p28, and a p72 came with the swap?
You can use either harness, but regardless, you will have to do some wiring.
If you use his harness, you'll have to run the wires from the shock tower to the ecu for knock sensor and IABs.
If you use your harness, you'll have to run the knock sensor and IAB wires from the engine to the ecu.
No clue on the tranny. You'll have to search for that one.
