CV joint prob
Old Dec 17, 2005 | 05:59 PM
si 1's Avatar
Default CV joint prob
The bolt that goes underneath the C.V. joint wasnt there when i bought it from this guy. So i found the bolt in his box of blots because i was finishing the car to get it running. So i tryed to put it on and its all striped and i cant get the bolt back on if any one has any ideas that would be great this is just a winter car 1990 CRX DX i want to try to keep it cheap thanks
Old Dec 17, 2005 | 06:03 PM
HondaHeddie's Avatar
Default Re: CV joint prob (si 1)
do you mean the LCA ball joint?
Old Dec 17, 2005 | 07:43 PM
si 1's Avatar
Default Re: CV joint prob (aal)
yea wops sorry
Old Dec 17, 2005 | 08:03 PM
rsca_crx's Avatar
bolt? cv? ball joint? what are you really talking about.
if it is the nut on the ball joint then-
get a new ball joint and castle nut.
Old Dec 17, 2005 | 08:06 PM
si 1's Avatar
Default Re: CV joint prob (rsca_crx)
its locked in what will happen if i drive it
isnt there somthing that i can do to hold it like weld it
Old Dec 17, 2005 | 08:14 PM
rsca_crx's Avatar
first, verify what you are really talking about to make it easier to help.
on the ball joint, (or any suspendion/steering/ brake component) this isn't the place to get ghetto with things. if you are really strapped for cash i guess you could try to knock one out of a junkyard knuckle without screwing it up or just getting another knuckle.
either way, bolt that **** up right. if (when) it comes off driveng because you rigged it you're going to be a whole lot worse off than if you bought 3 less beers and a new ball joint
Old Dec 17, 2005 | 08:43 PM
si 1's Avatar
yes it is the ball joint and the castle nut wont go on and im wondering if i can some how get that nut back on without spending money because im kinda running low because iv got four cars and im always putting parts into those and i didnt want to spend to much money on a crx i payed 200 for so i could use it as a winter beater because i want to keep my nice crx in the garage for winter.
Old Dec 18, 2005 | 03:06 PM
rsca_crx's Avatar
are the threads on the ball joint stripped? if they are, get another joint in there. a new one is cheap, and you can probably find a decent free used one if you have any friends with parts. if they are just crooked a die might help chase the threads, but there isn't a great way to hold it.
if it is the nut, buy a new one.
if it is spinning but the threads look good, then congratulations, you dont need a new one. put pressure on the top of it (the stock scissor jack above it works for lots of people) and thread the nut on.
dont rig it. it needs the nut tightened to seat properly, and it will come off and cause WAY more of a problem for you. sorry man, cars require maintenence, and this is an easy (and cheap) one.
kenzo42
Sep 5, 2013 05:45 AM
tuphatt
11
Sep 15, 2004 12:10 AM
g2man
Nov 27, 2003 09:53 PM
ransack
34
Jun 12, 2003 10:50 PM
