valve adjusting... need help asap. my car is apart
Old Dec 17, 2005 | 10:11 AM
idriveadelsol7's Avatar
Default valve adjusting... need help asap. my car is apart
when i adjust my valves... i start at TDC right. but the thing is where is TDC? do i line up the 3 marks where my timing is set at 16 degrees, or do i start at the 0 degree mark? i cannot take off the timing belt cover so i can't tell with that method.
Old Dec 17, 2005 | 10:15 AM
Archidictus's Avatar
Unceasing Measure
Default Re: valve adjusting... need help asap. my car is apart (idriveadelsol7)
TDC on the compression stroke <u><FONT COLOR="red">on each individual cylinder</FONT></u>. You have to rotate the engine for each cylinder. If you can see the camshaft sprockets, you should be able to tell when cylinder 1 (closest to the timing belt) is at TDC. After that, you use common sense to rotate the crank for each cylinder you need to adjust
Old Dec 17, 2005 | 10:19 AM
Default Re: valve adjusting... need help asap. my car is apart (Archidictus)
i see the back of it... it doesn't have the arrow ^ and the word up . i know how to do it, i just need to find TDC
Old Dec 17, 2005 | 10:21 AM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveadelsol7 &raquo;</TD></TR><TR><TD CLASS="quote">i see the back of it... it doesn't have the arrow ^ and the word up . i know how to do it, i just need to find TDC</TD></TR></TABLE>
So put a screwdriver in the spark plug hole and rotate the engine until it stops going up.
This isn't rocket science...
Old Dec 17, 2005 | 10:23 AM
Slopoke's Avatar
On the crank, line up the single white mark. The 3 marks are for ignition timing, so disregard them right now.
If you cant pull the timing cover off, the best thing to do is:
Line up the white mark on the crank. Now either #1 or #4 will be at TDC.
Try to wiggle the lifters. Which ever cyl is at TDC, the lifters will be loose.
You can adjust the valves with only having to turn the crank twice.
First line up the white line, and figure out which cyl is at TDC.
While #1 is at TDC, you can adjust all the valves on #1 the intake valves on #2 and the exhaust valves on #3.
Then rotate the crank 360 degrees and line up the white mark again.
While #4 is at TDC, you can adjust all the valves on #4, the intake valves on #3 and the exhaust vaves on #2.
Then your done!
Post up any other Qs.
Old Dec 17, 2005 | 10:26 AM
Default Re: valve adjusting... need help asap. my car is apart (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">On the crank, line up the single white mark. The 3 marks are for ignition timing, so disregard them right now.
Then your done!
Post up any other Qs.</TD></TR></TABLE>
**** i used the timing marks... i'll back back in another hour or so. thanks
Jake Bauer
Aug 21, 2017 01:32 PM
young geezer
May 21, 2009 08:37 AM
stagen
Dec 21, 2008 07:31 AM
90si_mugen_crx
Jul 25, 2005 03:09 PM
98b18black
Jun 26, 2005 12:24 AM
