Help, swap not staring up
Old Dec 16, 2005 | 10:08 PM
Cuong-nutz's Avatar
Default Help, swap not staring up
I just finished putting a D15B into my car. She turns over but is not firing up. Cam and crank are aligned. I can hear the fuel pump prime and the plugs are wet.
HELP ME OUT!
Old Dec 17, 2005 | 07:26 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Help, swap not staring up (Cuong-nutz)
make sure the tstat housing ground is tight.
Old Dec 17, 2005 | 08:29 AM
Targa250R's Avatar
be professional
Are you getting spark?
Old Dec 17, 2005 | 08:55 AM
Slopoke's Avatar
Default Re: Help, swap not staring up (Targa250R)
If the thermostat ground is off, the fuel pump wont prime, so its probably not it.
Sounds like your not getting spark.
Check your coil or ICM.
Old Dec 17, 2005 | 12:06 PM
Cuong-nutz's Avatar
I'm an idiot. I had the firing order wrong. Motor runs now...but I think I have a bad headgasket since I'm puffing white smoke out the tailpipe...
Old Dec 17, 2005 | 12:46 PM
Mr. Badwrench
Default Re: Help, swap not staring up (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">If the thermostat ground is off, the fuel pump wont prime, so its probably not it.
Check your coil or ICM.</TD></TR></TABLE>
you're right my bad.
CraigG
Feb 9, 2009 04:56 PM
trav143
11
Oct 8, 2008 10:58 AM
slowassciv33
10
Jul 1, 2007 04:04 PM
JSPECCRX
Jul 13, 2006 11:16 AM
evoalf
Sep 4, 2004 06:21 AM
