t25 on a mini me? anyone have this done??when do it stop making power?
Old Dec 16, 2005 | 09:29 PM
torqueless's Avatar
Default t25 on a mini me? anyone have this done??when do it stop making power?
ok heres whats going on, i have a d15b7 motor with a t25 turbo, it spools very quick but power falls on its face at 5800-6000rpms. so i have a vtec y8 head that will be put on very shortly, and i was wondering since the power band will be different, will the turbo still fall on its face at 6K? i also have a small 16g, i was saving to put on when i put the y8 head on, but i got anxious and put it on today, to see if it would gain more power on the b7, and it is definitley alot slower!
very laggy and doesnt pick up power till 6k(right when i have to shift.) but i will for sure use the 16g when the vtec head is on, but i was just wondering if the t25 would still only be good for 6k or if it would make more power for longer rpms do to vtec?
Old Dec 16, 2005 | 09:59 PM
mike93eh
Guest
Posts: n/a
get a z6 head, too many headaches with the y8 on anything other than a y7 or y8.
Old Dec 17, 2005 | 11:34 AM
torqueless's Avatar
Default Re: (mike93eh)
i already have the y8 head, and ive done 2swaps using that head, with nothing but great great outcomes and great power.
so anyone else want to try answering the question?
Old Dec 17, 2005 | 11:48 AM
dohcVTECeg2's Avatar
Default Re: (torqueless)
go for the ODB-1 D16Z6 head
Old Dec 17, 2005 | 12:34 PM
mike93eh
Guest
Posts: n/a
the y8 head requires MUCH less timing. what ecu are you using?
Old Dec 17, 2005 | 08:11 PM
torqueless's Avatar
with the other y8 heads that ive swapped on b7 i set timing at 10. p28ecu
Old Dec 17, 2005 | 08:13 PM
blingking1904's Avatar
hey do you kno whow to tell the negative and positive side on a stock OEM coil ?
Old Dec 17, 2005 | 09:33 PM
P h i l's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torqueless &raquo;</TD></TR><TR><TD CLASS="quote">i already have the y8 head, and ive done 2swaps using that head, with nothing but great great outcomes and great power.
so anyone else want to try answering the question?</TD></TR></TABLE>
im pretty sure ur compression will be alot higher with the y8
Old Dec 17, 2005 | 09:34 PM
P h i l's Avatar
Default Re: (blingking1904)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blingking1904 &raquo;</TD></TR><TR><TD CLASS="quote">hey do you kno whow to tell the negative and positive side on a stock OEM coil ?</TD></TR></TABLE>
use a digital multi meter
Old Dec 17, 2005 | 09:50 PM
torqueless's Avatar
Default Re: (crxhf89)
th ecompression is 10.2:1 wich is the same as if you were to use a zc head.
Old Dec 18, 2005 | 07:28 AM
hey would you be able to show me or tell me how to hook up a tach ?
Old Dec 18, 2005 | 02:09 PM
ek_chris's Avatar
it'll kick out at around 6000rpm. T25's are good for 2-6K rpm.. after that they lack top end. I have a d16y8 motor.. past 6000 is weak.
Old Dec 18, 2005 | 02:15 PM
13g-crx's Avatar
Default Re: (ek_chris)
same here. i had the 13g, which is very similar, on a y8. right after v-tec came in it fell on its face.
Old Dec 18, 2005 | 02:34 PM
phresh_5's Avatar
Default T25 works for me
196tq at 4400 rpm, is enough to get me goin'. Just shift sooner to stay in your power band longer. Might want to lower VTEC to about 45k.
Old Dec 18, 2005 | 09:31 PM
P h i l's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torqueless &raquo;</TD></TR><TR><TD CLASS="quote">th ecompression is 10.2:1 wich is the same as if you were to use a zc head.</TD></TR></TABLE>
if you used the z6 head i thought the comp would be arround 9.8:1
NEWcivicLOVER
Oct 29, 2008 07:27 PM
mattie_96
Mar 20, 2006 03:33 AM
roycivic92
Oct 1, 2004 03:26 PM
